View Poll Results: At approximately how many ZR-1 miles before solenoid failure resulting in overhaul?
25 to 30k miles 1 7.14%
30 to35k miles 1 7.14%
35 to 40k miles 0 0%
40 to 45k miles 2 14.29%
45 to 50k miles 1 7.14%
50 to 55k miles 1 7.14%
55 to 60k miles 0 0%
60 to 65+k miles 8 57.14%
Voters: 14. You may not vote on this poll
Old 06-27-2017   #11
lfalzarano
Default Re: Poll: How many miles before solenoid failed?
New ones are available on EBay for $196. http://m.ebay.com/itm/Delco-Remy-Sta...-/251400500053
Completely rebuilt (not fixed) are available from Jerry's Gaskets for $214, which includes the core charge. Free return and get $30 back with return of the old core.
Old 06-28-2017   #12
secondchance
Originally Posted by dredgeguy View Post
I am at 84,700 miles and all is original....better not jinx me! Like the old saying, "What, me worry"....I live in Wazoo land
Yup! WAZOO land is a great place to be for ZR-1s.
Old 06-28-2017   #13
QB93Z
QB93Z's Avatar
Your survey needs more choices.
My Yellow 1994 has 152,000 miles, starter never touched as far as I know. My Quasar Blue 1993 has 122,000 miles, starter never touched as far as I know.
I think it is a problem with GM starter design. I had a 1987 Trans Am (same era as C4) that had starter solenoid issues at ~ 120,000 miles. My son has a 1988 Firebird that has starter solenoid issues right now at >100,000 miles.
Old 06-28-2017   #14
Wow! Had no idea so many went so far without dying or I would have expanded the poll.
No problem. Just post the mileage and I'll post a summary once the poll has run its course.
Old 06-30-2017   #15
ZR1North
That's quite a range in reliability! After a half dozen "no-starts" in 2012/13, I replaced mine at 37,000 miles after trying all the mods to reduce resistance throughout the starter circuit to minimize the problem. I've since removed all the mods, as I think you're just delaying the inevitable (solenoid replacement) once you've experienced a no-start or two.
1991 ZR-1 (SN666) - Haibeck 510; 410s, Corsa, SW Headers; Hurst SS; DeWitts Rad; RC Injectors; LEDs throughout; `93 MF Sawblades
2016 Z06 - Stock
1971 Stingray 454 LS5 - Sold
ZR1North is offline   Reply With Quote
Old 06-30-2017   #16
One of the reconditioning items I always do on a ZR-1 no matter the mileage is the Starter Solenoid........as well as install the Relay to reduce the current through the Clutch Switch to the Starter Solenoid.
The Starter Solenoid is shown in the left photo with slight burnt contacts in right photo.
The Solenoid contacts in left photo were wire brushed clean in right photo.
Also use a bit of emery cloth on the two fixed contacts.
Starter Rebuild
Fixing the LT5 Starter is a rather small issue........But......You have to remove the Plenum and Coils to get at the Starter
Old 06-30-2017   #17
Starter Rebuild
Good point, Cliff. Thanks for the photos too!
Actually, I believe the "Achilles heel" is that copper ring and those "L"-shaped contact posts that become pitted and erroded; not the windings of the electromagnets so much. New "L" contacts can be had for around $10, depending on the source.
The solenoid kit, including the armature itself AND the "L" contacts is more. But, as Cliff points out, unless that copper ring on the armature is beyond repair, a little emery paper will restore it like new and save you several $$.
Furthermore, depending on where you get that armature 'kit', that skinny thrust pin (see Cliff's photo) may not be the proper length. The pin length affects the engagement of the starter pinion with the ring gear: kinda important, doanchaknow....
Old 07-01-2017   #18
gtcollins@maxnet.co.nz
Hi my starter started to play up with in 4 week's of purchase only when hot as in slow driving pulled the starter out cleaned all contact as they were like new fit a slave solenoid also gave the starter motor quick clean and lube works well now the starter motors are a Toyota starter and are used in a lot of equipment and the contacts wear out we replace them and the starters good to go again we just check the brushes I often fit slave solenoid to the equipment also especially with the after market copy of the starter Glen Collins
Sent from my SM-G930F using ZR-1 Net Registry mobile app
Old 07-01-2017   #19
Just one more item with the contacts when you tighten nuts that hold the contacts it can twist the contact a little so I us a flat punch and tap it flat again Glen
Old 07-02-2017   #20
bhedberg
The problem I had was the female connector on the purple wire that connects to the starter. The metal in the connector is bent to produce a spring action against the male spade connector on the starter when it is plugged in. Over time, and in the harsh environment of the valley, that metal clip loses its spring tension and does not maintain reliable contact. When I opened up the plenum and disconnected the purple wire, there was no resistance at all to the connector coming off. That could explain the no start when hot and then starting again after partially cooling off. The metal clip can be released from the plastic of the connector and re-formed (bent) to reestablish some spring tension in order to provide a positive connection. As a backup, I always carry a "starter stick" I got from Gordon years ago. It is a 3/16 inch steel rod about 30 inches long. When experiencing the no start, the rod can reach the starter with the hood up and probing behind the engine at the firewall. The method is to hold the key in the start position and tap tap on the starter with the starting stick. (easier with 2 people) The vibration from the tapping can reestablish contact and get the engine started. Release the key to the on position after it fires up. Of course there are other failure modes that produce the no start condition but I'd guess there have been lots of perfectly good starters tossed because of the connector. Some may have replaced a starter only to have the condition return soon after.
Founding #006
Former Membership Director
NCM member
Grand Sport registry
bhedberg is offline   Reply With Quote
