Old 06-26-2017   #11
Ccmano
Default Re: Starter solenoid rebuild-sometimes things just go bad to worse!
Don't feel bad, we all do things like that. A couple weeks ago I changed the fuel pumps on the Z. Got it all buttoned up, turned around, and laying on my work bench were the strainers that attach to the bottom of the pumps! Sh!t... I was so impressed at how quickly I could pull the pumps and replace them I left the strainers off. Had to pull everything apart again. Oh well.
H
Old 06-26-2017   #12
BlackZR1
BlackZR1's Avatar
Yes I did. It was after checking the length, I forgot to reinstall in the starter.
secondchance, do you have a source/part # for the plunger? I've looked far and wide for the correct length plunger but had to settle for cleaning up the old one like Paul did.
Thanks,
Roger
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 06-27-2017   #13
secondchance
Thanks,
Roger
http://www.nationsautoelectric.com/densoparts.html
Call Nations Auto Electric. They actually have a real tech on the other side who will go through the book, figure out LT5 specific starter and identify plunger and contacts.
OEM starter had smaller contacts on both sides. The kit came with one smaller contact plate and assortment of contact plates with elongated ears (?). I picked one that worked geometrically. OEM contact plate on one side had worn down noticeably more than the other side. I used elongated plate on the side with excessive wear figuring more meat will reduce the relative wear resulting in even wear on both sides.
If you want smaller plates on bothe sides like the OEM, just make sure they send you two smaller contact plates.
I think I will try rebuilding an alternator next time.
Old 06-27-2017   #14
HAWAIIZR-1's Avatar
Glad to hear all is well in the end Yun! I have had more than my share of similar situations so I'm there with you on this.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
Old 06-27-2017   #15
ssrszz4
Yes just sounds like a normal day at the office!
ssrszz4 is offline   Reply With Quote
Old 06-27-2017   #16
secondchance
Thanks guys for words of encouragement.
First heat soak test, 15 minutes after shut down, was a success! Hope I didn't jinx myself...
Old 06-28-2017   #17
BlackZR1
BlackZR1's Avatar
Thanks Yun I'll check them out.
Roger
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 08-15-2017   #18
BlackZR1
BlackZR1's Avatar
Here is the Plunger Part # for anyone looking for the correct part. Purchased from Nations Starter & Alternator (thanks Yun)
Denso 053660-7061
$21.95 + $8 shipping
I checked every dimension against the plunger in my new spare starter and they all check out, especially the 100.5mm overall length.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 08-16-2017   #19
Denso 053660-7061 $ 13.76 shipped on here.
https://www.finditparts.com/products...so-053660-7061
Old 08-16-2017   #20
As I rest my left foot on one of the original heads from my ZR-1, all I gotta say is...IT COULDA BEEN WORSE! LOL!
