Old 06-23-2017   #11
Default Re: Radiator
I am using that 3 core without any issues, but yes you have to modify the shroud for fitament
Old 06-23-2017   #12
Flyman 27
Flyman 27's Avatar
https://www.summitracing.com/parts/d...m/applications
I switched to Dewitt double row and never looked back.
Minor modification to fan shroud is necessary.
Thank you!
Flyman 27 is offline   Reply With Quote
Old 07-23-2017   #13
ssrszz4
I installed the 2 row Dewitt now all seems normal. My old one was probably 50 percent plugs!
ssrszz4 is offline   Reply With Quote
Old 08-20-2018   #14
lfalzarano
Look at a Dewitt 2 row core.
PRO-SERIES (2 ROW 1.0" TUBES)
This new aluminum radiator features two rows of 1" tubes and press formed end tanks. This doubles the cooling capacity of the original single row units. This design eliminates failures due to cracked plastic end tanks and/or gasket leaks. This unit fits into the original mounting however GM did not allow any room for a thicker core and therefore it is impossible to make a true Direct Fit[emoji768]. The upper two rubber cushions must be trimmed slightly to accommodate the larger core. We now include spacer plates and hardware so no shroud cutting is required!
About $549, but worth it. There are 3 row cores, but they may need the radiator shroud modified or the fan closures.
Lou
Old 08-20-2018   #15
secondchance
Last time my OEM radiator failed, resulting head gasket failure led me down to a mini-stroker build. Twice! Come to think of it, thank you GM! I love the journey I had to take...
Old 03-17-2019   #16
Karl
Karl's Avatar
What is the best way to remove the cooling hose going from the water pump to the thermostat housing?
I am in the process of changing the radiator out and want to change all the hoses also.
Thanks.
1993 ZR-1 #211 Yellow On Beige Beast #2
1992 ZR-1 #427 Black On Black *Sold*
1985 L98 Blue On Blue *Sold*
Old 03-17-2019   #17
Unbolt the housing from the frame
Old 03-17-2019   #18
Karl
Karl's Avatar
Sounds simple enough. Will finish it up next weekend. I was not dressed to crawl under the car today! Lol.
