Old 06-22-2017   #11
Tripler
Tripler's Avatar
Default Re: Should I be concerned....
Remove the rubber and put a rag around the gas filler section and soak it in WD40 spray and wipe down . It will drip a bit so do this over a cement floor or rags under the car . This will slow down the rust a bit and also just wipe off the access oil . I did it on our 1995 last spring and will do it again before winter .
Sent from my LG-H831 using ZR-1 Net Registry mobile app
Tripler is offline   Reply With Quote
Old 06-22-2017   #12
BigJohn
BigJohn's Avatar
Use white vinegar to pull out the rust first.
Old 06-24-2017   #13
Tripler
Tripler's Avatar
Good tip John . I did not know that ... Amazing what vinegar can do
