Old 06-20-2017   #1
Ccmano
Default Re: Sooty #7
Dom,
Didn't you have an issue when the porting was done with a pinhole leak in the injector housing? I wonder if this might be the same issue.
H
Old 06-20-2017   #2
Originally Posted by Ccmano View Post
Dom,
H
When I first ported the injector housing, I went thru the bolt boss at the very front of the IH. Vacuum leak into #2 primary runner. Welded that.
There have been other cases of oil seepage through a very porous casting of the cylinder head runner.
#7 is close to the PCV. Wonder if its related to crankcase venting and possible lack of restriction between IH and cylinder head.
Question for Mr. Haibeck.
Old 06-22-2017   #3
Interesting post I ran across while doing research on another topic. This appears to describe what I observed after doing the compression check.Same bank as well.
http://www.zr1.net/forum/showpost.ph...53&postcount=1
Old 06-20-2017   #4
jss06c6
Watching closely to learn!
Old 06-20-2017   #5
ssrszz4
I know that '90's didn't have exhaust valve seals and was designed that way on purpose.
ssrszz4 is offline   Reply With Quote
Old 06-26-2017   #6
jss06c6
Dominic,
Any updates?? Very interested to learn what is causing the fouling of #7 plug.. sure hope it's something "reasonably" easy to fix..
Old 06-26-2017   #7
Originally Posted by jss06c6 View Post
Dominic,
Right now there isn't a further update. At this point, we'll begin looking at it after the 4th holiday or sometime after that. Given the results of the compression test and checking of injector and plug wire resistance, there's nothing obvious. It could easily be a leaky injector. But right now that's speculation. It could be something more involved. I'll have Dr. Polatsidistein have a look and I will update.
Old 06-26-2017   #8
jss06c6
Thanks. Watching with interest..
Old 06-26-2017   #9
A fuel injector leaking would show up if you pressurized the fuel rail and observed the time it takes to bleed off pressure.
As I recall, it took over 15 minutes to bleed off the first pound of pressure when I did mine the last time, once I found the leak (a bad check-valve in a fuel pump).
One other thought: isn't the vacuum line for the pressure regulator just about directly over the #7 plenum runner? You know where I'm going...!
Just some things to ponder before pulling the motor...
Old 06-26-2017   #10
Well yes the PR vacuum line is by #7 but plenum volume is supplying vacuum so its hard for me to gather how it discriminates on #7.
