Old 06-07-2017   #11
Ronstar
Default Re: shelby wheels
do your fronts set out pretty far?
did having the center on the outside scar up the polished lip that that it sits on?
Ronstar is offline   Reply With Quote
Old 06-07-2017   #12
Tripler
Tripler's Avatar
Wow ... Those tires look like godzilla scales ! Cool !
Sent from my LG-H831 using ZR-1 Net Registry mobile app
Tripler is offline   Reply With Quote
Old 06-07-2017   #13
I attached a picture. But there was no marks or damage to the polished surface. Even if there was it is an easy fix on the Barrel
Old 06-07-2017   #14
Ronstar
Thanks. That's what I was looking for
Old 06-07-2017   #15
I was thinking Armadillo scales lol
Old 06-07-2017   #16
Are yours like that? I am running Michelin Pilot Sports 275/35R18 on the front
Old 06-08-2017   #17
Ronstar
Yes
Old 06-08-2017   #18
SO I think I can swap the centers back to the inside without too much issue. What front brakes do you have? OEM will not be an issue.. I need to check to see if my Wilwoods will cause problems
Old 06-08-2017   #19
Ronstar
I have grand sport calipers on mine.
Seems to me it shouldnt matter if centers are inside or outside for brake clearance. The mating surface and wheel spokes (which is what usually causes fitment issues) will not change position with respect to the hub/caliper. what really moves is the barrel only. i guess it would move the thickness of the polished lip (not Much) not the thickness of the centers
Old 06-08-2017   #20
The C5 brakes needed the clearance for the face of the spokes and then a bit more for the 2 lips of the Barrels..
I think I will be fine, I just never looked into it. I will say that with the centers on the outside, the spacers made the wheel 'fit' a bit better
