Old 05-11-2017   #11
Hog
Default Re: Throttle Body Primary Blade Wear Issue
When used, dag is applied only to the secondaries.
As in the 2 larger throttles in the t-body, or DAG is only used on the Port Throttles?
peace
Paul
Old 05-11-2017   #12
Jagdpanzer
Jagdpanzer's Avatar
Yes, the 2 larger throttle bores in the t-body
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-11-2017   #13
Hog
OK cool.
Just an illustration of the confusion which can occur when referencing LT5 parts as "secondary or secondaries is often used in reference to the Port Throttles.
I just saw a gentleman who is sell DAG-213 for $15.00. He said the quantity sold for $15.00 would be enough to do a few sets of throttleblades. He states that suppliers sell this product in large quantities, like over $500 per gallon and that it has a shelf-life of 24 months from time of manufacture. He suggest using the $15 tube amount that he sells within 30 days, and keep it in the refrigerator to help lengthen its useful life.
Here's his link, sounds like he's a carb rebuilder
http://www.pontiactripower.com/shop/...ade-sealer-dag
Or 5 gallons for $1550 down to 30ml for $25.95
http://www.laddresearch.com/chemicals/dag-213
peace
Paul
Old 05-11-2017   #14
Jagdpanzer
Jagdpanzer's Avatar
Over the years I've looked over several TBs and only one had DAG applied to the secondary throttle blades. This leads me to speculate DAG was applied during the factory dyno test if acceptable idle behavior could not be achieved otherwise.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-23-2018   #15
Phil,
Well doubtful there’s any DAG on bored out 63mm TBs like mine. I don’t experience any idle issues.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-23-2018   #16
Jagdpanzer
Jagdpanzer's Avatar
Dom,
Same with my 63mm TB
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-23-2018   #17
S.hafsmo
S.hafsmo's Avatar
Who does the 63mm job?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 02-23-2018   #18
jss06c6
Marc Haibeck..
Old 02-23-2018   #19
I took my throttle body apart a while ago, including removal of the throttle blades. The blade alignment is NOT something u can take for granted when u tighten the bolts. There’s enough play that they move around and can easily be out of alignment with it not taking a mm or less to screw things up. I ended up w a sticking throttle.
I took it to Marc for realignment and he also provided a “helper” spring to make sure things close.
Old 02-23-2018   #20
grahambehan
DAG Was applied at the Tbody production facility, it is used to control the "Shipping air rate" of the unit on the test fixture. AKA Leakage
Graham
grahambehan is offline   Reply With Quote
