Old 05-07-2017   #11
Default Re: Any risk in swapping radiator caps?
Originally Posted by RussMcB View Post
Have you tried to find a local place that has loaner tools or can test your cooling system pressure for you? (As mentioned before) That will tell you exactly what you need to know in order to decide what you should do to fix the problem.
http://www.autozone.com/landing/page...me=loan-a-tool
I concur with this recommendation.
Reducing the system pressure is a patch on a likely small problem that can result in premature boil-over in an engine that is somewhat prone to overheating in certain conditions. With summer coming on, it's the best time to make sure the cooling system is in top condition.
