Old 04-26-2017   #11
Roadster
Roadster's Avatar
Default Re: High idle after driving
This may be another alternative.....
https://www.amazon.com/CRC-03084-Net...85HQ5ZSCY3T8Z2
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-27-2017   #12
S.hafsmo
S.hafsmo's Avatar
Molycote D321R is also an option, but that one is rather expensive. I'll see what I can find locally, and do a little experiment.
A little googling shows that this is an issue on many cars. The Skyline RB26 for one. There's even a "throttle coat" out there.
http://www.tomei-p.co.jp/_2003web-ca...ers_gauge.html
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 04-27-2017   #13
Roadster
Roadster's Avatar
Interesting, is there anyway to transfer that into English???
Found it, also expensive...
https://store.outperformance.com/pro...mei-981019.htm
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-27-2017   #14
S.hafsmo
S.hafsmo's Avatar
I've ordered a bottle from the Netherlands. It doesn't work like the OEM stuff, but if it doesn't work I assume it'll just wipe off.
- '90 ZR-1
Old 04-27-2017   #15
G8nightman
G8nightman's Avatar
here is what I used
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 04-27-2017   #16
Roadster
Roadster's Avatar
Originally Posted by G8nightman View Post
here is what I used
I already have that on the shelf....lol, but not the industrial strength. I sprayed that on my mailbox lock and the coating is still there on the inside from over two weeks ago.
I also ordered the CRC version listed in a previous post. Looks like my TB is coming off in the next few days....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 04-28-2017   #17
S.hafsmo
S.hafsmo's Avatar
Just got the following reply from the Netherlands,
The Tomei Throttle coat is no longer available. We have the same stuff from Molykote available if you wish. Let me know if you prefer a refund or the alternate product.
I've asked to which product they refer.
Edit: They sell the Molykote D321R as a replacement, so I've ordered an aerosol bottle of it.
- '90 ZR-1
Old 04-28-2017   #18
ssrszz4
I found it on eBay the throttle coat that is.
http://www.ebay.com.au/itm/181995009727
ssrszz4 is offline   Reply With Quote
Old 04-28-2017   #19
ssrszz4
http://justjap.com/tomei-throttle-coat.html
Old 05-09-2017   #20
S.hafsmo
S.hafsmo's Avatar
Originally Posted by Roadster View Post
Seems like we have similar problems.....lol
Do you have a Tech 1 or scanner that will read the IAC counts? It would be interesting to see what your IAC is at idle. Hopefully we will both get our issues resolved......Good luck!!!
I've now received my Tech 1A and as expected, the IAC counts are 0 when the high idle occurs. I have not yet tested when it's cold.
When I parked today after a rather spirited drive, the idle was approx. 970 RPM, and after stop/start it stabilized at 770, so a 200 rpm drop by just restarting the car.
The Molykote D321R was stopped in transit, because it's "dangerous", so I've ordered it elsewhere. An expensive experiment at $120 for a bottle of spray.
Another issue has appeared, though probably unrelated. The battery voltage was 13.2 volts (on the Tech 1), which is way to low. Faulty voltage regulator? Increasing the revs did not seem to affect the voltage.
- '90 ZR-1
