#11 |
![]() Join Date: Nov 2016
YIKES!
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() |
#12 |
![]() Join Date: Dec 2003
I would recommend you remove the entire thermostat housing to replace the nipple. The original nipple is made of pot metal & is fragile with age. Go easy to avoid breaking it off. If in doubt, apply heat to the housing around nipple.
If it does twist off, take it to a competent machine shop for removal & thread chase. DO NOT TRY TO USE AN EASY-OUT. Thermostat housings are rare & expensive. Sent from my iPhone using ZR-1 Net Registry
