Old 03-14-2017   #11
Kevin
Kevin's Avatar
Default Re: Maintaining aluminium looks?
Originally Posted by S.hafsmo View Post
Wouldn't the polished aluminum oxidize quite rapidly if left untreated?
Edit: Didn't see your post, Kevin. What do you use to seal after the polish?
I use opti-seal. I also used the polish to do the inside of my wheels which had some really nasty build up after years of neglect. I sealed those with opti-seal too. Should be a bit easier to clean up now...I hope.
Old 03-14-2017   #12
S.hafsmo
S.hafsmo's Avatar
Originally Posted by ghlkal View Post
If you need to clean it first, use Eagle 1 etching wheel cleaner - works very well.
see http://www.corvetteforum.com/forums/...r-carrige.html
Appreciate it. Much good info in that thread.
Kevin,
I've heard good things about Opti-seal, or Optimum Gloss Coating as they call it now (At least I think it's the same), so I'll probably order a tube of it for testing purposes.
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 03-14-2017   #13
randy ransome
randy ransome's Avatar
That is extremely nice.......how long did it take and how did you accomplish the original polish?
I assume with all components polished on the bench?
Fortunately I wasn't the one that initially polished everything. The former owner had the Pleasure of doing that. As I remember he said he had somewhere around 100 hours in the process and yes it was apart when he polished it. He clear coated it all after polishing but it had Yellowed over time. Time and heat aren't kind to the old, clear paint. I stripped the clear coat off everything and re-polished it. I didn't consider re-clearing it after all the work stripping it.
randy ransome is offline   Reply With Quote
Old 03-14-2017   #14
Kevin
Kevin's Avatar
Kevin,
opti-seal is a spray
https://www.amazon.com/Optimum-Opti-...f_rd_i=desktop
Old 03-14-2017   #15
S.hafsmo
S.hafsmo's Avatar
My apologies. I was thinking of Opti-coat. Appreciate the link.
- '90 ZR-1
Old 03-14-2017   #16
Kevin
Kevin's Avatar
Opti-coat usually requires a professional to apply, or so I'm told
Old 03-15-2017   #17
HAWAIIZR-1's Avatar
Default Maintaining aluminium looks?
I have had good success with Rejex on all my polished aluminum. I can't really say how long between applications as I have not kept track and it varies on use and conditions.
http://www.rejex.com/
I use it on my paint too. I started using their products about 10 years ago due to the salt air in Hawaii.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
