Old 02-26-2017   #11
secondchance
Default Re: Has anybody ever replaced the HVAC Programmer?
Great to hear you have zeroed in where the issue was.
Old 02-26-2017   #12
dredgeguy
dredgeguy's Avatar
Progress is a good thing! Let me know if you need another pair of hands.
Charlie
__________
Dredgeguy
Dana 4:10 gears
Polished LT5 by Haibeck
Old 02-26-2017   #13
Roadster
Roadster's Avatar
Originally Posted by QB93Z View Post
Then I determined that the vacuum tubing between the plenum and the Programmer may have been kinked behind the Passenger side hush panel.
Jim, you lucked out on that one, no need to remove the HVAC programmer is a big plus!!!
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 03-10-2017   #14
QB93Z
QB93Z's Avatar
I received the Heat Blend Door Motor that was supposed to be for '93-'95 that I bought on eBay. I installed it in the car with confidence that everything would work properly.
Well, I have the same symptoms that I had with the Heat Blend Door Motor from the 1991. When the controls are set at 90 degrees, (calling for heat), it blows cold air out the lower vents. When the controls are set at 60 degrees, (calling for AC), it blows hot air out the AC vents on the dash.
I suspect that the motor that the eBay dealer sent me is not really the late model version.
Pictures to follow.
Old 03-10-2017   #15
QB93Z
QB93Z's Avatar
In this pic, top is the controller from my 1994. The corrosion from the AC condensation has damaged the small motor. Below it is the motor from the 1991.
There is a difference between them. The wiring to the motor is reversed:
I swapped the motor leads to reverse the direction and tried it in the car again. The blend motor appeared to run in the correct direction, but it only moved a small amount then stopped. I believe that the unit has a position signal that goes to the HVAC Programmer. So that signal has to be reversed as well.
1990 Black ZR-1 - sold
1993 Quasar Blue ZR-1
1994 Competition Yellow ZR-1
1995 Dark Purple ZR-1
Maryland State Coordinator
Old 03-10-2017   #16
QB93Z
QB93Z's Avatar
Both the 1994 and the 1991 unit have the same GM part number: 16124952
Does anyone know how to identify the correct version in the parts sources?
Old 03-10-2017   #17
did you disconnect the battery before putting that assembly back in? if not do that for a minimum of 30 seconds.. then try again. Blend door will calibrate and then you can control it
Old 03-10-2017   #18
QB93Z
QB93Z's Avatar
You are correct, and I forgot to do that the last few times I put the unit in. I will try it.
Thanks, Jim
Old 03-12-2017   #19
S.hafsmo
S.hafsmo's Avatar
Did the 30 sec recal. help?
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 03-12-2017   #20
QB93Z
QB93Z's Avatar
No, I still had the same symptoms. I have been retracing all my steps in this drawn out trouble shooting process. Now I am wondering if the wiring harness from the main harness to the Heat Blend Door Motor makes a difference. It occurred to me that I have been using the harness from the 1991. I have gotten busy with other projects and haven't had a chance to test that theory yet.
