#11 | |
![]() Join Date: Nov 2016
Do you mean the radiator shroud, the fan shroud or both? Is this a "nice to have" or a "need to have" The FSM does not say anything about that? I just did that repair last weekend and is was a complete time suck, so I'd like to avoid it if necessary. ![]() Thanks!
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() Last edited by GOLDCYLON; 02-08-2017 at 03:01 PM. |
#12 | |
![]() ![]() ![]() Join Date: May 2007
#13 |
Well, I MAY have ducked a bullet......
I put the oil cooler hose on last night and took the car out for a "test drive" for about 12 miles at various speeds. Jerry's lines installed without too much trouble. I'm happy with the quality and the fact that I could bend them to route around other hoses so they don't touch. So, Before I left, there was clearly water/antifreeze residue around the gasket area. I was expecting to see something when I got back When I got home I did the inspection and found no wetness or residue. I checked two hours later (after cooling a bit) and found nothing. This morning still dry and ZERO drips on the pan. Did the engine heat "burn off" the anti freeze? My guess is that the wetness was still a left over from when I washed the engine over the weekend? Seems like a long time to still be wet, but I have no other explanation?? It is good to be good, but way better to get lucky.
Bill Schroeder Texas Proud! 1991 Corvette ZR1 #1388 2015 Challenger Scat Pack Shaker ![]() |
#14 |
![]() Join Date: Feb 2011
I had a similar problem with my car after putting on new cooler lines. There was so much oil dripping onto the garage floor a couple of days after the repair, I thought my cooler had a pin hole leak...I took it all out and pressure checked it in my bathtub. went ahead and cleaned the radiator... no problems found...it turned out the lower radiator cross member had so much oil left in it that it was still leaking from there.
#15 | |
1990 ZR1 Red/Black #2469 1990 ZR1 Black/Black #843 1993 ZR1 Ruby 40th Anniversary #112 |
#16 | |
Yours is a 90? If I remember those are a bit wonky. The big thing is to clear your computer memory and history if possible.
#17 |
The Texas boy's are a lucky bunch , having Corey in your backyard is a huge plus !!
#18 |
Yeah Don tried that with paper clip and with tool someone on the registry sold him. Didn't work.
#19 |
Did you clean the air bag frame sensors and mounting points removing all the rust and apply a healthy dose of dialectic grease. The 90s are famous for the INF error? No way to clear a code until that is done. GC
#20 |
Drivers side was done 4yrs ago. So I'm guessing its passenger side.
Guessing that is what Cory is going to do. It's a bit of a drive, 3 hrs, but I can do it in a day.
