01-28-2017 | #11 |
Re: oil pressure sensor socket
Goldcylon are the oil pressure sensors the same on your 90 and 91?
I'm wondering if a previous owner may have replaced it with something other then stock.
Gary 90-1572 |
01-28-2017 | #12 | |
Here is why there are different sensor body heights The GM Part # is:12555492 NIEHOFF OP24471 DURALAST PS206 VALUCRAFT OP8165
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 01-28-2017 at 04:07 PM. |
01-28-2017 | #13 |
Tom, so far everything is going as KPW explained. I only had to loosen the tensioner though to get the lower driver side alternator bracket bolt. It's really a tight space. Used a magnet to keep from dropping the 10mm bolt on the rear bracket.Until I get the oil pressure sending socket I won't be able to wiggle the alternator out and disconnect the power cable.
Gary
Gary 90-1572 |
01-28-2017 | #14 |
Goldcylon unfortunatly ALL my local auto parts stores only had the shorter sockets.Spent 2 hours going to them.
I will have both sockets in a few days though.
Gary 90-1572 |
01-28-2017 | #15 | |
Tom 1994 ZR-1 #009 "captured test fleet car" 1974 LS4 454 Vert 1982 L83 CFI...now a retired "dd"....Sold WAZOO Member |
01-28-2017 | #16 |
Ok well that works.
02-04-2017 | #17 |
Gary,
Did the socket get delivered the other day? And how is progress going on the replacement alternator???
02-06-2017 | #18 |
Tom,
Just received it today.If I get home early enough I'll do some more during the week,otherwise it will be the weekend. Did you get yours changed?
Gary 90-1572 |
02-06-2017 | #19 |
Gary,
The replacement from Autozone is scheduled to be delivered tomorrow. Decided to do more things in the meantime. Replacing headlamps, cleaning the wheel well covers, etc., etc. Also received replacement brushes for the original alternator. I may just rebuild the original, and put that unit back in..... Glad the socket came, I know you'll be glad to finish that job....
02-11-2017 | #20 |
Tom, Is it only me or does everyone have these problems. The socket didn't fit. I then was able to force an adjustable under the water hose and turn it enough to get another bite. I was feeling desperate and if something else broke or was damaged so be it. Well I got it out. Then I checked the socket to the bottom of the sensor and guess what it would not fit the 1-3/16 base period. It was deep enough.I got another 1-3/16 socket and it fit fine.Go figure the new socket I waited to come from california on horse back was out of tolerance so far it wouldn't work.
Gary 90-1572 |
