#11 |
![]() Join Date: Jul 2012
The ASR can be removed and replaced with 90-92 cables without issue. Gets rid of the clutter and you get a slight improvement in throttle response.
Sent from my XT1254 using ZR-1 Net Registry mobile app
'95 ZR-1, aqua/gray, #167 368 LPE/Haibeck, Web cams, Stainless Works headers, B&B Fusion exhaust, 18" Fikse wheels, Alcon brakes, lowered. 491 SAE RWHP. |
#12 |
![]() Join Date: Aug 2006
The way it's engineered, ASR has no correlation with throttle response. If anything, vacuum secondary system affects throttle response.
#13 |
Note I said slight. Due to the direct connection from throttle pedal to the throttle cam. Just feels a little better. No change in engine response.
#14 |
![]() Join Date: Jun 2005
Interesting about ASR. I hated it when my engine was stock. It was too intrusive. When I had the late Jim Van Dorn modify the engine to the 500-hp level, ASR's level of intrusiveness became more acceptable.
#15 |
I would agree. I drive w ASR On. Even experimented w ASR by leaving ON taking off from the line, then punching it to OFF once I leave the line and have traction. Crude "launch control".
#16 | |
![]() Join Date: Sep 2008
I was trying to avoid the wheel-spin in 1st and 2nd that would occur with stock tires as I hit and passed through about 5500 RPM. Thought it might fight the tendency to get squirrelly before and after those 2 shifts. I guess I must not drive it hard enough anymore, as I no longer am bothered by the invocation of traction control. I am usually thankful that the damn nanny actually helped! ![]() Marty |
#17 | |
#18 |
![]() Join Date: Feb 2012
Keep them tires turning???
#19 |
#20 |
Cold tires cold pavement no stickie!!!
