#11 |
![]() Join Date: Apr 2007
Another aside, West and East Germany were reunified in October 1990 so its understandable ZF black tags made after that date were labeled "Made In Germany"
#12 |
![]() Join Date: Nov 2013
Thanks Craig, I checked mine over and it's good. No noise or roughness. If dynamite needs it, it all his. Thanks again!!
1994 ZR-1 #198, sold [img]https://live.staticflickr.com/65535/48400173802_2a6f122cfb_n.jpg[/IMG] [COLOR=RoyalBlue]96 GrandSport#857[/COLOR],[COLOR=Red]Red Gut[/COLOR] 397 LT4, AFR heads,3:90 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla... Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60' Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60' 2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11 @112.18 w/1.71 60' |
#13 | |
![]() Join Date: Mar 2014
"Jim told me that they (the OE's he has now) are NOS bearings from years ago. However, they are only for the 94-95 ZR-1. And they are only for the Blue Label ZF trans, which came into service with the 94 model. Now, there is an exception to this and that is when the 94 MY assembly started, there were not any Blue Label transmissions available, as there were still some Black Label transmissions still available from the end of the 93 MY build. So there are some early 94's that probably have the Black Label trans that were installed at the factory. If you have an early 94 with a Black Label, then these TOB's are not for you." But to my understanding the amount of "black tags" that were installed in 94's is unknown, as is the last serial number known, before switching to the "blue tag" trans. I have to look at mine again, but I am most sure I have a "black tag" trans....
#14 | |
![]() Join Date: May 2016
Craig, I might b interested in the early model bearing...should fit my 90' right? Joie Sent from my iPhone using ZR-1 Net Registry |
#15 | |
Black tag = built in germany. Blue tag = state side. 90-93 early style. 94+ later style. No need to go into details im sure you all about the differences but thats how I have it. |
#16 | |
Now if a person wanted to discuss a '92 or '93 610 Nm vs maybe a 540 Nm that's entirely possible. There's very likely a mix in there somewhere! Through the years there's been much "Internet Lore" regarding the ZF S6-40! Black/Blue - 610 Nm/540 Nm - Black tags were built with both and the blue tag were all the lesser. |
#17 |
![]() Join Date: Dec 2003
Transmission info from my 1994 ZR-1
Black Tag, "Made in Germany" Type: S6-40 (stamped) followed by ZP 309 (hand engraved) Parts List No: 1052 000 081 Transmission No: 032289 Customers Ref No: 10212759 Oil Capacity in LTS: 2.0 (hand engraved) Numbers matching #234 Collar diameter: large, 1.378"/35mm
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 12-26-2016 at 01:14 PM. |
#18 |
Out of curiosity now, I have 3 throw outs from my GS. They look identical to the one out of the Z. The original one (yes I'm a pack rat) has the same markings on the bearing seal. All the dimensions between them are pretty much the same. The non original 2 were included with Centerforce clutch kits. One bearing has Japan on it the other China. They all fit on the trans the same.
#19 |
![]() ![]() Join Date: May 2010
Okay, Rich. Glad to hear okay and will do. Best wishes and you're welcome.
Craig "ZR-1 NO KA 'OI" "ZR-1 ICHIBAN" 1995 #228 Black/Black with Dunn Heads ZR-1 owner since September 2003 ZR-1 Net Registry Founding Member #0074 NCM Lifetime Member #2048 ![]() |
#20 |
OK Cliff, I'll reply to your PM if you want it. This is my last ZR-1 and when it dies I'm done.
