Old 12-03-2016   #11
billschroeder5842
billschroeder5842's Avatar
Default Re: Tail pipe halfsies?
Thanks Bob.
Since I'm fully confused on exhaust modifications, I'll employee the first rule of "Rocket Travel" which is "When in doubt, do nothing different." I'll run my stock for a while.
BTW... I'm from Lake County. Raised on the Chain O Lakes and lived in Grayslake.
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
[SIGPIC][/SIGPIC]
Old 12-05-2016   #12
Originally Posted by billschroeder5842 View Post
Thanks Bob.
Hi Bill--
Well, we got our first snow yesterday--a couple of inches of wet heavy stuff. I am sure you don't miss that!
You may have seen other posts on this subject, but what I did after 20+ years of various loud exhausts on my ZR-1s was to return to my stock '95 exhaust (since the late model system has a low restriction resonator) and I added electric cutouts in front of the mufflers. Best of both worlds--stock look, quiet sound when I want it and anywhere from a low rumble to wide open straight pipes if I am racing or just want to scare small children. If you search for "cutouts" you will probably find lots of detail on mine and others. My system on the '95 (which I sold last Feb) had headers and no cats. But nothing wrong with doing nothing. The stock system still sounds pretty good if muted somewhat. Take your time and listen to as many systems as you can to get a sense of what you might like. Overall, simply enjoy the car-they are really a lot of fun. --Bob
Old 12-07-2016   #13
jss06c6
Bill,
My '91 is full Stainless Works, headers to tips, you can listen to mine and Dave's Corsa system this weekend in Buffalo..
Steve
Old 12-07-2016   #14
Fully Vetted
Fully Vetted's Avatar
I've got SW headers and Corsa from the headers back with no cats. Plenty loud with no drone on the highway. You'll hear it when we drive down. See you Sat morning!
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 12-07-2016   #15
billschroeder5842
Thanks- I'm looking forward to "hearing" everyone's opinion on exhausts.
(yes, my wife thinks my jokes are bad too)
Bill Schroeder
Texas Proud!
[SIGPIC][/SIGPIC]
Old 12-07-2016   #16
mike100
Don't buy mufflers with dual outlets unless you want to limit your trips to 25 minutes or less. I had made up some c6 NPP vacuum actuated valves for my stainless works mufflers.
You can hear the drone in this video- it is worse in the car.
http://s29.photobucket.com/user/msch...f3c58.mp4.html
Old 12-08-2016   #17
So Mike, u pass Cali emissions w the headers and cats?
Are u saying u get drone w the Z06 NPP?
Old 12-08-2016   #18
mike100
No, sadly, the long tubes and LS7 cats had to come off to pass the visual part of the inspection. Depending on if I still have the car in 2017, I wanted to do aftermarket mufflers on my stock exhaust set with bmw vacuum actuators I have.
The big 3" SW catback with their fairly loud mufflers still droned lugging in 6th gear, but generally speaking, it didn't drone with the flaps closed.
Old 12-08-2016   #19
Bob Eyres
Bob, those cutouts ahead of the mufflers look slick.
My car has headers, no cats, no resonator, and a 3" X pipe and 3" B&B system all the way back. It produces the dreaded drone, but I'm a masochist and love it. The loudest version is to drop the mufflers at the track. A 50lb. weight saving, and the nastiest shriek a stock Corvette can make. (and a 2mph. increase in trap speed.)
Your conversation makes me wonder if 3" mufflers with Helmholtz tuning are available?
Old 12-08-2016   #20
Actually, Bob, that is exactly what Marc Haibeck has done since he bought his car in 1993. He welded three bolt flanges just ahead of the mufflers and always removes them for a drag race. Gets a weight saving but also says it is a bit of a pain in the butt to remove them each time. Said once that if he had to do it all over again he would probably do what I did. I really don't know what aftermarket mufflers are out there with Helmholtz resonators today, other than Corsas.--Bob
