Old 10-25-2019   #11
Hib Halverson
Default Re: Bilstein Revalve Settings for FX-3
For information on SRC click here.
Also the correct name is "Moraca Valving". It is often misspelled as "Moroco" but the valving was named after the guy who first developed it.
If you guys can find someone other than Bilstein who can valve SRC shocks that way, go for it. The improvement in "Tour" alone is worth the price of admission.
I had Moraca-valved shocks on Barney and, in the 19-years I owned the car, that was the best single suspension mod I did.
Hib Halverson
Technical Writer
former owner 95 VIN 0140
current owner 19 VIN 1878
Old 02-10-2021   #12
rexrcr
Originally Posted by emmvette View Post
... I spoke with http://deltavee.net/services/ and they are happy to do the work, for about $800 / set but they don't know what the Marlin or Marocco spring rate / settings are which have already been successfully developed.
Hello, thanks for the link to our site. I do have the Corvette/ Bilstein valving information.
The best way to get in touch is email: rob@deltavee.net
Thanks!
rexrcr is offline   Reply With Quote
Old 02-11-2021   #13
Erik
Thanks!
Excellent. Thanks very much.
1990 ZR-1 # 996
"All Corvettes are red. The rest are mistakes." - John Heinricy
Erik is offline   Reply With Quote
Old 02-13-2021   #14
Corvette95
Corvette95's Avatar
I am looking for 89-92 good (working) fx3 shocks to send in for rebuild and revalve and cosmetic refinish.Turn around time is too long to send in mine. Don?t need the actuators. Budget is limited. Let me know what you got and price thanks!
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
Old 02-17-2021   #15
rkreigh
good to hear there is hope for the old fx3
I'm looking into going with some adjustable coil overs and be done with it.
the adjustable fx3 is cool, but for me "set and forget it" works just fine and if I can get an the setup for less than a shock rebuild, I'm headed that way.
If anyone needs a stock DRM fx3 coil over setup look me up. I'll be selling it.
95 390 LPE ZR1 (505 rwhp)
Old 02-17-2021   #16
VikingTrad3r
VikingTrad3r's Avatar
so how does this work? stock fx3? with a coilspring around it? then remove the leafs? do u beef up the rear or front suspension mounts?
VikingTrad3r
Calgary, Canada
1991 ZR1 # 888 - daily drive whenever possible
1991 ZR1 engine from unknown sn.
1990 Z51 zf6 being built into narrow body ZR1 racer
1987 z52 auto - sold
1986 'z31' 4+3 - sold
1985 Z51 auto - sold
VikingTrad3r is offline   Reply With Quote
Old 02-27-2021   #17
rkreigh
the drm coil overs are very simple. they machine a c clip groove into the shock housing and add alum "hats" and a coil spring over the stock fx3
I talked to Dave M. about coil over and if you bang over curbs at the track you are likely to crack the shock towers. The racers would cut a shock tower out of another car and weld it in to double up.
But on the street its not an issue and my ccws will bend long before the shock towers crack (ask me how I know) Durability is quite good.
don't get too greedy on spring rates and big rims or it will ride like an old 84 z51 and knock your fillings out and slam your head into the top on whoop do dos (again ask me how I know)
Once I got "reasonable" and went back to 18s with a non run flat tire and softer springs (425 up front 275 in back) car rides GREAT and sticks like glue
I also tossed the banski rods in there to replace the stock dog bones on the rear tie rods and stuff too. Freed up the suspension and really made the car less skiddish around bumpy corners. Really like it now, much more "planted" feeling and I'm more confident pushing harder.
The old LSV has seen some hard miles and will see alot more of them lord be willing
Old 05-29-2021   #18
VikingTrad3r
Thanks!
Rob, are you still available to do this? No reply on emails.
VikingTrad3r
Calgary, Canada
Tags
bilstein, revalve, shocks
