Old 11-13-2016   #11
Roadster
Roadster's Avatar
Default Re: FX3 actuator rebuild/roll pins
In addition to what the OP has posted, I also did some research. Could not find the Gedore 1.5 mm pin punch, but did find one from South Korea made by Smato. There are 4 left in the 1.5 mm size if anyone is interested.
Auction # 361759427841 Cost $7.35 and free shipping.
Also found some Serpent 1.5x10mm Roll Pins (10), these are solid and not the split ones that are also offered. I would imagine that these will work just fine.
Auction # 401103591073 Cost $7.68 which includes the shipping and shipped from CA. He has 2 more sets available as of this time. Not the great price that the OP got from China, but these are very hard to find along with the 1.5 mm pin punch.
I placed my order for both items...
Just thought I would pass this along......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-23-2016   #12
Roadster
Roadster's Avatar
Received the roll pins last week and received the pin punch from South Korea yesterday, which was extremely fast. I imagine that since the package was so small it made through customs without any problems. The 1.5mm pin punch and the roll pins match up perfect. Just have to cut them down to 6mm whenever needed. I may pick up the split roll pins just to have......
Thanks to the OP (orthodoct) for all the info.....into the tool box they go.....
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-23-2016   #13
secondchance
Now, try lining up the pin with the gear and shaft lined up, AND squeeze it in. It's like trying to butt xxxx a gnat! Excuse my Korean...
Old 11-23-2016   #14
Roadster
Roadster's Avatar
Now, try lining up the pin with the gear and shaft lined up, AND squeeze it in. It's like butt xxxxing a gnat! Excuse my Korean...
I hear you there Yun....... hope I never need them at all. But for the price, I feel it's cheap insurance for if it does happen....I always try to be prepared, but that doesn't always happen.......anyway it's another tool for WAZOO Land, don't know if Jim has this tool and the pins or not.....but we have one now or maybe two......
1974 LS4 454 Vert
1974 L-82 355 Vert.
Old 11-23-2016   #15
secondchance
I did this a couple of times. I think the last time was about 3 years ago. It can be done! Good eyesight, steady hand and a good needle nose pliers is what it takes.
Old 11-23-2016   #16
I Could not find the Gedore 1.5 mm pin punch, but did find one from South Korea made by Smato. There are 4 left in the 1.5 mm size if anyone is interested.
I must of lucked out I was able to order at Gedore on Ebay nice punch
Old 11-23-2016   #17
orthodoct
Hi secondchance. Regarding lining up the holes, I am spoiled with acesss to some incredible instruments as an orthopaedic surgeon. There is an instrument known as a pointed towel clip that we use to secure drapes around a surgical field. They have tapered points and when the tips are passed through the holes in the gear and shaft of the shock, they line up he holes perfectly. BTW, Captain Z CNC now stocks the 1.5mm by 6.0mm pins needed to install the gears. If some one can tell me how to post a picture, I'll take a picture of the towel clips and try to find an online source. Roadster, I noted the "Serpent" brand on your punch and roll pins. I built two of their gas powered remote controlled cars. Awesome machines; 0-70 REAL mph in two seconds! They were kits, $1500 each not including engine or radios, made in Holland. Still have them upstairs in my theater room on display!
orthodoct is offline   Reply With Quote
Old 11-23-2016   #18
orthodoct
Correct name for towel clip is Backhaus Kocher Towel Forceps; not cheap, but a unique and useful tool.
Old 11-23-2016   #19
secondchance
Talking Re: FX3 actuator rebuild/roll pins
Backhaus Kocher Towel Forceps, huh? I think I lined up the holes with the punch, squeezed in the pin through the gear, turned left and right until I could feel the hole on the shock shaft followed by additional squeeze with the needle nose. Wasn't easy but got it through. All with just my thumb and index fingers.
Old 11-23-2016   #20
orthodoct
Told you that I was spoiled! The tapered nature of the tips of the towel clips corrects any rotational malalignment and centers the holes perfectly.
