Old 11-07-2016   #11
efnfast
Default Re: New cams
Well, I knew these cams wouldn't sit around long. The plan is:
Install the cams
New lifters
Time them
Port the heads, matched to the IH's
Remove the secondaries
Install exhaust valve seals
Replace the rod bearings
Tune
SS bolts
Powder coat the cam covers
Light weight pulleys
Miss anything????
Old 11-07-2016   #12
Install the cams
New lifters
Time them
Tune
SS bolts
Miss anything????
Block Throttle Body Coolant at Each Injector Housing!!
Injector Housing TB Coolant Blocking
Dynomite is online now   Reply With Quote
Old 11-07-2016   #13
efnfast
Already done!
Old 11-07-2016   #14
Install the cams
New lifters
Time them
Tune
SS bolts
Miss anything????
Start a Thread on your Restoration/Modifications with some photos....will be very interesting
Old 11-07-2016   #15
efnfast
Well, this is the thread. Pictures will be the problem.
Old 11-07-2016   #16
Tune should be
TUNE
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 11-18-2016   #17
efnfast
Car heads to Dempseys (Oricle) next Friday. As long as the roads aren't salted.
Old 11-21-2016   #18
Fully Vetted
Fully Vetted's Avatar
Definitely interested to see the results. I was hovering over the "I'll take'm" button when you took them. I've already got all the other stuff done.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 11-21-2016   #19
Oh. Lord...won't you buy me...a set of new cams
My friends all have got them....I MUST MAKE AMENDS!
OH, LORD, won't you buy me...a set of new CAMS!!
That's it!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 11-21-2016   #20
efnfast
Well, sorry for all the drama, but I put the project on hold again.
