10-29-2016 | #11 | |
Re: Coil Problem
Did you disassemble the throttle blades?
10-30-2016 | #12 |
Re: Coil Problem
No I did not disassemble the throttle body or remove it from the plenum. That issue seems to be better so I'm focusing on the original problem of the ignition system. Looks like I'll have to pull the plenum again. Need to take another look at the plug wire on number 5, it ohm'd okay on its own but I didn't completely remove and inspect it, perhaps it rubbed on something and is grounding? Also going to check the wires between the coils and the DIS module.
Robert ZR-1 Net Registry Oregon State Director 91 ZR-1 #431 Black/Black LPE 368 |
10-30-2016 | #13 |
Re: Coil Problem
Any chance something is arcing off the starter, thinking of the fuse problem I keep having on the 91 build
10-31-2016 | #14 |
Re: Coil Problem
Fuses look good, no codes set.
10-31-2016 | #15 |
Re: Coil Problem
I also checked the primary side of the 8-5 coil I removed and it OHM'd within spec so it appears the coil is not the root problem.
10-31-2016 | #16 |
Re: Coil Problem
I just talked to MSD's tech support and they are favoring a problem with plug wire #5, specifically a bad connection where the wire snaps on the coil tower causing arcing and corroding the tower. The wires are Magnacore and probably 10-12 years old. Looking at the ignition schematic from the DIS each coil has its own hot wire and two coils share a ground. This would seem to limit the possibility of a problem with the DIS module, phew, I hope.
10-31-2016 | #17 |
Re: Coil Problem
If you haven't already, how about just starting the motor and then twisting the #5 plug wire to see if u can induce a miss. Obviously protect yourself from any
shock. Also wait till it's dark out and then start the motor. See if any arcing is visible either under the plenum or from wires.
10-31-2016 | #18 | |
Re: Coil Problem
10-31-2016 | #19 |
Re: Coil Problem
Not suggesting u pull the plug wire, but try twisting it and see if it affects anything.
10-31-2016 | #20 | |
Re: Coil Problem
