Old 10-09-2016   #11
secondchance
Default Re: Steering rack
Either way you got to pull the rack while you are there I suggest going to poly bushings. Don't forget your going to need an alignment afterwords are well
Yes. Four wheel alignment is a given.
Check out this YouTube video. I'll take another look under my Z. According to this video, although not a C4, may be able to replace the rod without disassembling the whole front end.
https://m.youtube.com/watch?v=05XOhz67jGA
Old 10-09-2016   #12
Yes let me rephrase what I am saying it is easier to pull everything out and quicker as you have to r and r the rack anyway so go ahead pull the rack. With the amount of miles you have on the car it's time. Anything can be done I was suggesting what was easier and smarter since you are already replacing the rack. Does this make Sense? Also why I suggest poly bushings because you have to pull everything apart. I also suggested a source for a new rack.
Old 10-09-2016   #13
secondchance
I hear you. Guess better to do it once as opposed to partial followed by another later.
Old 10-09-2016   #14
Yep that's what's I'm trying to say. Also that rack I recommended comes with new tie rod ends included if I remember correctly
Old 10-09-2016   #15
secondchance
Ebay pic, although it says generic pic, does not show rod ends.
Goldcylon. Did you install the one you got from ebay listing you shared with me? Just want to make sure I get a quality rebuild piece. Don't want to do it twice.
Old 10-09-2016   #16
Not yet I've been waiting for it cool down here in AZ it's still in the 90s I can take a pic of it in the box on the floor of my garage if you like. If you send in the core it's supposed to have a life time warranty
Old 10-10-2016   #17
lbszr
lbszr's Avatar
Turn one may be a Good resource also. I have not used them yet, but have heard they have good reputation.
Turn one steering. http://www.turnone-steering.com/rebuilding-services.
Old 10-13-2016   #18
batchman
Inner tie rods can usually be changed in-the-car no problem with the correct tool, which is admittedly not in many home tool boxes. You need a guy with the 6' high and 10' long Snap-On chest to find those.
If you do decide to send the rack out, Turn One is the only place I would even consider.
As to the prior ratio posts, there is a big difference and we found the quick rack worth the (very difficult at that time) chase.
One other tidbit for a steering thread... Another surprising difference in a Z51 car is the "hockey puck" rag joint. The ZR-1's have the usual canvas one. Another big difference.
Pretty sure the slow rack and rag joint are part of the Driveability and NVH folks' concerns for their well-heeled original customers.
Cheers,
- Jeff
