Old 09-03-2016   #11
WVZR-1
Default Re: 90 degree adaptor for Fuel Pressure Test Hose
You never cease to amaze me with your infinite wealth of knowledge.
That makes 2 of us
Sorry to disappoint - I should have checked further!!
But I believe that ain't correct for the external thread of the fuel pressure Schrader. I looked further and I do think it's very likely 4AN - if I were looking to fabricate a 90° adapter I'd take the cap and check the cap against a 4AN first. That thread would make it 7/16-20 and an OTC 7430 adapter matches that for thread dimensions. -32 TPI is considered I guess "small Schrader" in fuel pressure language.
This adapter is part of the higher $$ Actron pressure kit
https://actron.com/content/right-ang...hrader-adapter
All of the "higher end" gauge packages will likely use what the OP has mentioned finding.
I used a Cornwell Tool kit to sort "nomenclature"
http://www.cornwelltools.com/webcat/...aster-Kit.html
I was going to try the AC connectors
Refrigerant/AC is 7/16-20 I believe.
Old 09-04-2016   #12
BlackZR1
BlackZR1's Avatar
The routing I use works ok for a straight fitting, see this pic.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Full-time secondaries, 4.10 gears, C-beam plates, ported top end
BlackZR1 is offline   Reply With Quote
Old 09-06-2016   #13
A straight fitting is all I use too, FWIW. I hadn't thought of running the hose under the alternator bracket tho.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-06-2016   #14
Billy Mild
Where did you get the extension hose for the FP Gauge?
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 09-06-2016   #15
I bought mine from Harbor Frieght.
90 #1202
Sans secondaries
Old 09-06-2016   #16
BlackZR1
BlackZR1's Avatar
I looked for an extension hose I could plug n play but couldn't find any so I made one up for my Actron CP7838 tester. https://www.amazon.com/Actron-CP7838...=Actron+CP7838
I unscrewed the hose fitting from the gauge (hose has a male 1/8NPT) and bought a 5' length of 1/4" ID fuel line to fit in between using 2 of these 1/4" barbed 1/8NPT male fittings and a 1/8NPT female to female coupling you can buy at Autozone. Gage -> barb fitting -> ext. hose -> barb fitting -> coupling -> original hose. I also used a hose clamp on the barbed fittings for safety and made sure nothing leaked before I took it out on the road.
Roger
1990 ZR-1 #2699
Black on Black
15,000 miles
Old 09-08-2016   #17
Ryan Chappel
Ryan Chappel's Avatar
That photo looks like something from an aquarium supply house.
Or the local bong store!!!!!
Ryan Chappel is offline   Reply With Quote
Old 09-08-2016   #18
BigJohn
BigJohn's Avatar
