Old 09-08-2016   #11
bdw18_123
Default Re: Forum Constantly Requires Me To Re-Login...annoying
In the other recent thread on this issue that Bob (Warp Ten) started, Carter mentioned that there was a setting under the "options" menu that he changed and that solved the issue for him, but he couldn't remember what specific setting it was.
I don't know if this is what Carter did, but for me the number of times I get logged out has been significantly reduced, but not gone altogether now after doing what I outline below:
If you have a newer version of Firefox, there isn't a "tools" heading anymore, you click on the 3 horizontal bars in the top right corner under the "X" that closes the browser out. In that window, click on options, it will open up a new tab. Click on "Security" and under "Logins", there should be a button that says "Saved Logins...". I found that there were some saved logins from a long time ago from an older version of the forums. I deleted everything related to the zr1.net site.
So it's not a complete fix, but it seems to be better than before.
[IMG]http://i13.photobucket.com/albums/a292/bdw18_123/_zr1netforumsigphoto.jpg[/IMG][B]
1990 Corvette ZR-1 [/B][I]
White/Flame Red, #2299, mostly stock, 144K miles.[/I]
-Cams timed to the '93-'95 405HP LT5 stock timing.
-IAT sensor relocated to below front bumper.
-Haibeck hoops installed in airduct.
-OBX cat-back exhaust.
[COLOR=DarkRed][B](SOLD - December 2012 [/B][/COLOR][COLOR=DarkRed][B]:hello:)[/B][/COLOR]
1993 Corvette Coupe
Black/Black, 6-speed
(SOLD - October 2009 :hello:)
Old 09-20-2016   #12
KJL
I tried to check the box there but of course it wont let me for some reason...
1995 ZR1 #159
1992 ZR1 #280
1996 Collectors LT4 (Stock)
572 rwhp
Old 09-29-2016   #13
emmvette
emmvette's Avatar
I have had this same issue for at least 2 years, using Windows 7 and internet explorer.
I still have this issue. I don't have this issue for any other forum.
[CENTER][SIZE=4][COLOR=red]1990 ZR-1 Red / Red[/COLOR][/SIZE][/CENTER]
emmvette is offline   Reply With Quote
