08-31-2016 | #11 |
Re: Clutch and Rear Diff Upgrade Experience
Concur how many of us have tools just like this one that made life a hell of a lot easier and then never had a job to use it again lol. I have a drawer of a few of those.
09-02-2016 | #12 |
OMG!!! That tool is awesome! I bet it works great on teeth as well!
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
09-02-2016 | #13 |
Goldcylon, I notice you have a Dewitts radiator. I installed one in my 96 LT4. It was when they first came out with the units that had an extra row. The thicker unit presented some challenges but when all was siad and done, I was happy I did it. Can really see the difference. How difficult was it to install in the ZR1?
09-02-2016 | #14 |
Anyone have the part number for the
correct DeWitt aluminum radiator for our cars? Best place to buy? |
09-02-2016 | #15 | |
If you order from Dewitt, it's $529.99 plus shipping. If you order the same from Summit Racing, it's $529.99 including shipping. I don't know why you get better price on Dewitt from Summit than you would from Dewitt. KJL, Only modification is to shave about 1/4" off internal fin separating primary and 2ndary fan (when you remove the shroud back panel, you will know what I mean) on the back panel of the radiator shroud. |
09-02-2016 | #16 | |
Course, I coulda stuck my engine hoist in the cabin and used my vise grips and rigged some coat hanger wire between the hoist hook and the vise grips...
09-02-2016 | #17 | |
I'll check out Summit. After overheating (no leaks or steam) at Carlisle in 95+ degree heat and bumper to bumper traffic all the way back to the motel, radiator replacement is on the Winter to do list. 26 year old plastic radiator, it's time... Ran 6 hours home to CT without incident. In the meanwhile, blew out the air side with compressed air and flushed with Simple Green and garden hose. Lotsa dust and crap came out! Of course, removing the radiator and back flushing would be better, but that's enough for now. The car has never overheated before and the guage always indicates just shy of halfway. Last edited by Mystic ZR-1; 09-02-2016 at 04:56 PM. Reason: . |
09-02-2016 | #18 |
09-02-2016 | #19 |
It was so hot that....
Hot enough to turn on the warning lite. Guage was in the high end of the scale, the numbers on the guage are there for looks... 95+ degrees, heavy bumper to bumper stop and go traffic with the AC on, can't blame the car... Both fans running, (Marc's chip...) no steam or over flow, overflow tank level was fine. Note: It's amazing how many overflow tanks you see empty... Glad I put on new hoses this year... Immediatly turned off AC and turned on the heater wide open @ max temp. Pulled into a parking lot and let it cool for 45 minutes or so and waited for traffic to ease before finishing short trip remaining to motel. Later in the evening after cooling, started and ran fine with no issues. Next morning told Marc all about it, he didn't get all excited just recommended that radiator needed a good external cleaning. He said not to worry about it, but keep an eye on it.. Ran fine not overheating on the way home to CT Saturday, still about 95 out... Lotsa crap when I did my half baked flushing, good enough for the time being... |
09-02-2016 | #20 |
For the 90-92 This link below is helpful in determining coolant temperature (deg C) unless you have 93-95 which will give you coolant temperature in deg F using the Gauges button on the Trip Monitor (Temp shown on Speedometer).
Just remember you are shooting for around 100 deg C (100 deg C is 212 deg F) on HOT days (100 deg F). Using HVAC Display for Engine Coolant Temperature Sent from my iPhone using ZR-1 Net Registry
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-02-2016 at 09:59 PM. |
