06-10-2016 | #11 |
Re: Hi Idle
And I was simply pointing out that throttle plate openings are, technically speaking, vacuum leaks. IACs create regulated vacuum leaks also.
06-14-2016 | #12 |
Re: Hi Idle
Accomplished the task of isolating each vacuum line independently and found several joint connection blocks leaking. Repaired the connections with silicone, no leaks noted. Reassembled intake runs like a LT5 should with 19 inches of vacuum! Thanks guys for the help!
06-14-2016 | #13 | |
Re: Hi Idle
06-14-2016 | #14 |
Re: Hi Idle
No, applied silicone to the hard line after cleaning then inserted to the end coupling let it semi cure reinstalled.
Sent from my SM-G925P using ZR-1 Net Registry mobile app |
