Old 09-05-2017   #11
Default Re: FS 1990 ZR-1 Convertible Body w/title
Sorry, Curiosity is getting to me.. Are all the body parts in primer or multicolor?
I don't know much about the C4 vert top frames, will this particular car accept the Glass rear window?
Old 09-10-2017   #12
shawn8492
Originally Posted by Blue Flame Restorations View Post
Empty body, converted into convertible "correctly" as this is the only way I do things. Doors original to the car. Hood.
Modified NEW convertible deck lid that attaches just like a factory GM convertible. Installed one piece convertible rear upper surround panel with absolutely no seams to ever bleed through. This is done right.
Even the ZR-1 Spyder had a pieced together rear upper surround panel with seams. I would say that this is the only correct ZR-1 convertible upper surround panel there is. When the mock-up was done, the rear 1/4 panels were left attached to the body. The convertible center section was seamed in and then the mold was made. The deck lid was modified to fit the 1/4's.
There are no bumpers or rocker panels included.
Has clear title.
When you sat "empty body" does this mean no dash or wiring also?
Thanks,
Shawn
shawn8492 is offline   Reply With Quote
Old 09-10-2017   #13
shawn8492
If it is not a glass window frame, it can be converted to one.
Shawn
Old 09-10-2017   #14
shawn8492
Brett,
Are you going to make the rear clip and decklid to sell?
Shawn
Old 09-16-2017   #15
Car was originally red. Original ZR-1 car converted to convertible.
Has NO interior pieces. No dash, etc. EMPTY SHELL
Convert top will as an original C4 corvette does. hardtop would also fit.
No bumpers or rockers.
YES, I will sell the convertible panels for $2k. You would have to source your own convertible hardware from Ebay.
There have been a few converted. From what I've seen, not always done where everything lines up right. This is done perfectly. No seams. Bonds in factory bonding areas.
This would be a pretty straight forward conversion if someone had a running car and wanted it converted.
I've done the R&D and crafted the molds. Someone else can do the easy part.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 09-17-2017   #16
I would LOVE to have a wide body Convertible.. Challenge I have is space which could probably be worked around, but the time is the killer,
Also moving a carcass around with no wheels could provide to be a challenge as well.. the positive to this would be getting it all painted prior to swapping things then you could paint it what ever color you wanted
the negative is there is NO Space for anything in a C4 vert behind the seats
Old 09-22-2017   #17
RHanselman
RHanselman's Avatar
I'm game... Left a PM and voice message...
Cheers,
Ron
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 09-26-2017   #18
Pete
Pete's Avatar
Hi Ron
If you need a couplete ZR-1 to finish your convertible.
I have a complete running 1990 ZR-1 i will sell for $10K
shipped within the 48.
Also PM'd you.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 09-26-2017   #19
RHanselman
RHanselman's Avatar
Going to convert my Ruby. Thanks for thinking of me!
Ron Hanselman
Founding Member #80
Old 09-26-2017   #20
So a Snake Skinner bodied ZR-1 Convertible?
