05-22-2016 | #11 | |
Re: Flat Plane Crank LT5
Thanks. I thought the name denoted basically a 180 journal config.
05-22-2016 | #12 |
Because of this configuration they are absolutely insane when under boost.
05-23-2016 | #13 | |
Would u explain further why that is?
05-23-2016 | #14 |
I believe it is because of two things. It's ability to rev so quickly due to less rotating mass and it's ability to evacuate its exhaust so efficiently. These things are nothing but giant air pumps. If you shove air in, especially under boost, you've got to get air out at the same rate or it robs power.
I did misspeak earlier. The 5.2 is not the Coyote engine. The Coyote engine is an 11:1 compression 5.0L yielding 435HP/390 lb ft of torque. The 5.2L FPC is the Voodoo engine that comes with 12:1 compression and yields 526HP at, wait for it...7500 RPM! With a redline of 8250! IMHO, this is the modern day LT5. A bean counters be damned engine that changes the rules and flips the bird to those that want to play on a level playing field. And the only car this engine is available in is a Shelby. Here's a great article on the Voodoo engine: http://www.powerperformancenews.com/...e/#prettyPhoto
_________________ 1994 AB/Grey #141 430 RWHP/392 RWTQ FBI Lyposuction / Secondaries relieved of duty / SW Long Tube Headers / Corsa Exhaust / FIC SS Injectors / MSD Coils / Lightweight Pulleys / Corey tuned B & M Shifter / Aluminum Flywheel / Samco Hoses / Shelby Series One's / C4 No Flex Frame Stiffener BBC - Bling By Carter: Custom ZR-1 Center Caps / Custom Plenum Plate / Air Box Knobs / TB Cover / Oil Filter Cover Last edited by Fully Vetted; 05-23-2016 at 04:49 PM. |
05-23-2016 | #15 |
Here is some sound with some revs
https://www.facebook.com/holger.hove...2992382110799/ David Hetrick |
05-23-2016 | #16 |
Wow.
05-23-2016 | #17 |
Should we start a "Show us your Crank" thread....oh, uh...maybe not
05-23-2016 | #18 |
Sure, here's my 4" Bryant
05-23-2016 | #19 |
Not often you can brag about having a 4 inch crank
05-23-2016 | #20 |
