#11 | |
#12 |
Here's another sound, not sure it is related to the clunk. I only hear it when I leave a stop sign.
https://www.youtube.com/watch?v=NWRoRBPQT1A I'm now officially upset by the quality of the ZR-1. Got a new problem showing up week after week after week. |
#13 |
What are you torquing the axleshaft nut too?
I did 175 ft/lbs and for a few days the click noise was gone, now its bad. I replaced the washers too and used antiseize on the shaft splines. |
#14 | |
Sucks to hear your frustration I feel that way a lot of times . |
#15 |
Someone else mentioned this to me on Instagram but they had a rattling and clunking noise may low speeds and it was the hatch struts. They were worn and they were rattling over bumps. Did you check the end links or replace them ?
#16 |
Billy Mild, I haven't touched the axle nut since I got the car. If it is not too much of a pain, I'll try to torque it.
5ABI VT, pads are a good idea. Sometimes when I break, I'm hearing that typical worn brake pads sound. The noise is there only at low speed, until about 10 mph, when I accelerate. For the initial clunking noise, I'll open my hatch tomorrow and see if the clunk goes away. I did not check the end links yet... Thanks for your support guys! |
#17 |
Can try pulling the ebrake slightly when accelerating from a stop see if the noise stops. Also don't forget to check the torque on the wheel bolts.
#18 |
![]() Join Date: Feb 2012
Sway bar bushings?
#19 | |
For the clunking sound, maybe (but I doubt it). 3 local garages checked everything underneath and it was all fine, including "official state inspection". |
#20 |
![]() Join Date: Jan 2015
Is the clunking a steady frequency, such as every wheel or driveshaft revolution? In other words, do you hear the clunks twice as fast when you're going 10MPH compared to 5 MPH?
If yes, the problem is in the drivetrain (transmission, driveshaft, differential, halfshaft, hub/wheel/brakes). Do you have a small video camera (i.e., GoPro)? Perhaps you can mount it close to different components (close enough to help hear the clunk source). I think the audio might be more useful than the video. I have a cheap mechanic's stethoscope. Perhaps you could use one, or have a passenger use a big long screwdriver in a similar fashion, hold it against the shifter the see if the clunk is coming from the trans. Maybe since it's only at low speeds it's related to first gear? (wild guess). I like the e-brake suggestion earlier. That's a good way to see if it's related to rear pads, rotor. Can you put on different rear tires/wheels for a test drive to see if the clunk goes away? Can you put a buddy in the back with the hatch open to see if it's coming from one side (or from the front or back)? Changed trans and diff fluids recently? Anything other than clean oil come out? Can you hear a clunk when the rear wheels are turning with the car up on jack stands? Good luck. Last edited by RussMcB; 05-27-2016 at 08:11 AM. |
