Old 04-01-2016   #11
WVZR-1
Default Re: Can't read SES codes
Originally Posted by MuRCieLaGo View Post
The (car) electrical shop is well reknown where I live. They pinned back the wire, and now everything seems to be fine on the car. No more SES, no more SRC.
I identified the repaired wire. If something goes wrong again, I'll use your infos and go from there.
Thanks a lot WVZR-1 and Dynomite, I appreciate your help.
So long as they saved your terminal OR COINCIDENTALLY had a "plated" terminal you should be "golden". If they used a tin plated or a terminal with no seal then it's still not considered repaired I'd think. Good to see you're rolling though and it's "error free".
Old 04-01-2016   #12
MuRCieLaGo
I'll keep an eye on it!
MuRCieLaGo is offline   Reply With Quote
