View Poll Results: Are you interested in larger diameter sway bars.
No interest at all. 5 45.45%
Front 30 MM sway bar 0 0%
Rear 26 MM sway bar 0 0%
Both front and rear sway bars. 6 54.55%
Voters: 11. You may not vote on this poll
Old 03-11-2016   #11
lbszr
lbszr's Avatar
Default Re: 30 Front Sway Bar
Originally Posted by RussMcB View Post
I'd be very interested in an adjustable anti-sway bar.
Is that in scope?
It would be nice to change the car's balance easily.
Couldn't get it to paste. But car tech stuff by Richard Newton shows adjustable rear made by dj racing. I wanted to do that this winter, but didn't get around to it.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 03-12-2016   #12
RussMcB
Can someone remind me what size bars our cars came with?
I measured mine today and they are both 26mm.
Thanks.
Old 03-12-2016   #13
cvette98pacecar
Thanks.
26T Front 26S Rear. T=Tubular, S=Solid.
Robert J. DeMarco
[SIGPIC][/SIGPIC]
NCM Lifetime Member #2655
Pacecar Registry Member
1991 Shinoda Aerobody Spyder,
1998 Pace Car
Old 03-25-2016   #14
batchman
Didn't see this until now, I don't get to the forum (and particularly this sub-forum) much. FWIW and this was a while ago...
On stock springs and bars our car was crazy loose even with proper alignment. Bumped both springs, still so. Dropped the rear spring (1/2 way back to stock) and bar and became much more neutral. Bumped the front bar and had much better camber control, did not go to push except on trail-braking. Oddly I am not sure, but am starting to think a little loose may be fastest for a transition heavy thing like autocross.
Next setup (for this season) I'm working on more spring/shock and expect to drop front bar from 32S to 32T. Probably will look to try a 19mm rear bar too.
Cheers,
- Jeff
[/I]
Last edited by batchman; 03-25-2016 at 07:03 PM. Reason: had development path out of order
