Old 02-14-2016   #11
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Winter Project - Intake Valve Upgrade
Together with new cams target is around 50 hp.
Dom, are you referring to the Cosworth lifters I recall Sam mentioning a while back. Has anyone seen a spec sheet on these?
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-14-2016   #12
SAM/CH ZR-1
Phil,
Did you install bigger valve seats?
Sam
DR.Z/LT5-Performance
1990 #1822 with 383 cui
SAM/CH ZR-1 is offline   Reply With Quote
Old 02-14-2016   #13
Jagdpanzer
Jagdpanzer's Avatar
Yes, 42.85mm OD
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 02-14-2016   #14
Not sure if Cosworth or Porsche. I know Sam can fill you in on them. A set of them is circling O'hare right now as I understand it. Significantly lighter I was told.
Old 02-15-2016   #15
SAM/CH ZR-1
I did send out before to the company a stock LT5 lifter for measuring and checking all components and sizes and if the light lifters match. Also I told them about the weight of all moving parts and the spring pressures. The leight lifters can handle with.
Sam
