#11 |
![]() Join Date: Nov 2014
Metal upgrade is good for sure but if my gears are fine ill just replace the balls, if both are shot ill get the whole kit
#12 |
![]() Join Date: Mar 2013
It is the plastic rollers inside the gears. Just replaced them on 4 headlights. Gears were in perfect shape but I replaced with plastic gears anyway. The metal gears cost a lot of money. I would stick with plastic. My gears had zero wear. I could have reused them. I would have been pissed if I sprung the extra for the metal gears. The head lights also for some odd reason fail closely together so buy parts for both and use a good plastic compatible grease.
1995 ZR1 #159 Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp 1992 ZR1 #280 Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp 1996 Collectors LT4 (Stock) 1972 Convertible 434 Small Block 572 rwhp |
