Old 01-27-2016   #11
Default Re: Some Differences between 95's and 90'/91's
The drain tube actually runs between the back of the block/oil pan and in front of the flywheel.
Valley Drain Port looks larger on 95' and goes from Valley into Bell Housing in front of Flywheel and then out with a large port in the Bell Housing Lower Cover plate (shown in photo looking upward in front of Bell Housing Lower Cover Plate and behind Rear of Oil Pan). No tube extends down as the Drain Port appears too large for a tube.
I actually applied engine degreaser and pressure washed the valley and the Larger Drain Port functions very well. I think if the Valley Drain Port on the 95' is not clogged with leaves that one could actually pressure wash the engine with no issues. I will add a photo of the Valley in a moment.
Valley with New Crankcase Cover Gasket installed
Old 01-27-2016   #12
You forgot the door storage pods 94-96
Old 01-27-2016   #13
Is the hatch release backside of the passenger door still there? No Tire changing light either, Down in one window was on the 94 and up as well
Old 01-27-2016   #14
No Hatch release on passenger door but does have Hatch release on Key Fob.
Old 01-27-2016   #15
secondchance
I believe 94s and 95s have softer springs but firmer shocks. 94s and 95s are raised a bit more than early cars to keep softer springs from causing nose scrape. I thinks this is achieved by extra rubber pads on the underside, outer edges of the front spring.
Old 01-27-2016   #16
Coupe89
I dont recall an EGR on the 90. I'll look again....
1990 ZR-1 #642
Coupe89 is offline   Reply With Quote
Old 01-27-2016   #17
secondchance
No EGR until 93 (I think...). 94 and 95s have EGR.
Old 01-27-2016   #18
Windshield
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 01-28-2016   #19
Demps
Demps's Avatar
Windshield wiper to blade trunnion (different blades required)
Shocks
Shock gears
ASR & associated "stuff"
Master Cylinder
ABS (95 LT1 was upgraded & some say LT5 was too--can't remember)
Rear door jam "locker"--silver alignment pin
Rear storage compartments
Top wrench
No top bumpers (on inside frame) on 95s
Hood emblems & associated alignment holes
Selectable data on speedo LED
Old 01-28-2016   #20
Originally Posted by USAFPILOT View Post
Crash through shifter was on the 95. It is the only feature on the 95 I wish my 94 had. Though there are others.
As Phil noted, go with a Hurst and eliminate the lift ring. I did that on my '93 and there is plenty of spring loading to keep you from putting it in reverse instead of fifth or sixth. Never had a problem and loved not having the lift ring. --Bob
