Old 10-07-2015   #11
Default Re: Clutch Out, Which Should I Buy?
Originally Posted by We Gone View Post
??? I thought the splines on the ZF for a ZR-1 were different from a base Corvette ZF??
Input shaft is shorter for base C4.
Old 10-07-2015   #12
Listen to the above , Jerry has the right RAM system for you.
Old 10-07-2015   #13
efnfast
Frank, do you have experiance with the Ram stuff? I do.
Old 10-07-2015   #14
rbidwell
If you are close to Henderson Performance, ask him about the clutch and pressure plate out of my car. Very few easy miles. They are replaced as they may not have handled my power increase. Will sell cheap.
rbidwell is offline   Reply With Quote
Old 10-07-2015   #15
BigIke
Bidwell, what was the clutch?
I spoke with Jim at length, I like how my clutch engages and disengages. Looks like i'll be going with a NOS pressure plate and clutch, will reface the flywheel.
Old 10-07-2015   #16
rbidwell
I'm not sure what clutch it is. I had put in when SGC did the 368 build. I doubt if is has 5000 miles on it. I used it with an aluminum flywheel. I'm sure Corey can give you better information. Good luck with your project.
Ron Bidwell
Old 10-08-2015   #17
Kevin
Kevin's Avatar
you can't reface the flywheel
Old 10-08-2015   #18
WVZR-1
Not necessarily correct, I believe that Jandik actually "resells" them. DMF's have been resurfaced for years but successfully only by "the talented few".
Old 10-08-2015   #19
Been using the RAM DD in my car since 2010.
Old 10-08-2015   #20
I will confirm Dave's statement. I was talking to Jim J. just 2 days ago & this specific topic came up. Doing the job correctly does require "the talented few".
