Old 09-24-2015   #11
efnfast
Default Re: Fuel injectors..Factory or aftermarket?
Jerry's Gaskets carries replacements.
Old 09-26-2015   #12
Vette73
Sent a few photos to Marc and they are Accels and ethanol tolerant...
Thanks for all the feedback....
Vette73 is offline   Reply With Quote
Old 09-26-2015   #13
Hmm I thought all Accels were labeled.... Just like the RCs
However if they are indeed Accels they have stainless inserts.
Old 09-26-2015   #14
You'll want to get the "O" ring seals (new) from Jerry, and let him know (I'm sure he'd ask) that they're for a 91. Also, Jerry has the proper gaskets as well.
Is you motor top end ported? If so, of course you'll need to cut the gasket port holes to match the porting. I use an exacto knife after plugging the runner with a oily rag first.
Check w/ Jerry, but I don't use any gasket sealer on the (under side of the) gaskets, except for sealer around the coolant port. However, before placing the gasket on the motor, I DO spray the plenum side of the gasket with silicone lube to act as a release agent. In this way, next time I need to get under there again, after removing the bolts, I can slide a thin putty knife between the gasket and the plenum and slide it down the length of the gasket (on each side). This usually results in the gasket sticking to the IH, but frees easily from the plenum. I've re-used that gasket up to 3 times w/o leaking, if I'm lucky enough the gasket doesn't crack anywhere first. (In any case it should be good for at least 2 uses!)
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
