Old 09-23-2015   #11
MuRCieLaGo
Default Re: Do you guys have anything to add to the ZR-1's buyer guide?
Oh, I'm surprised by what you say there (compression test). I thought these engines were bullet proof!
How do I run a vacuum test?
MuRCieLaGo is offline   Reply With Quote
Old 09-23-2015   #12
Like any other motor: over heat it, don't change the oil and air filter (worse run w/o one!) and they're like any others; bearings, scoring, i.e. damage can occur. Also, a compression check will provide clues as to loose cam bolts (shifting cam phasing some - rare, but easy to check compression just for ease of mind; normal stuff to check).
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 09-23-2015   #13
Billy Mild
Make sure to vacuum test it. Use a mity vac and pull vacuum on various hoses that connect to the intake manifold. These can always be fixed, but the plenum needs to be pulled to do so.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
