Old 08-25-2015   #11
Fully Vetted
Fully Vetted's Avatar
Default Re: What are these M10 holes for?
You'll need to remove the rear wheel so a jack and jackstand is needed but honestly you're not even under the car. If it wasn't for needing to drill that one hole (which is why you have to remove the wheel) you could almost do it with it on the ground.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 08-25-2015   #12
Kevin
Kevin's Avatar
the prototypes didn't have the hole drilled, I was considering not doing it. I've had these things sitting in my garage for a year tomorrow. Bought them at carlise last year. Wife's banned me from buying more stuff till I install these...I need to get on it
Old 08-25-2015   #13
BlackZR1
BlackZR1's Avatar
Originally Posted by Kevin View Post
If you were looking to get a frame stiffener I'd go with https://www.vette2vette.com/?q=produ...r-bar-system-5
I have one in the garage, just need a lift to instal it
That's a nice kit Kevin. Looks well made. A bit pricey though.
Description says "does not require any body modifications to install. The system bolts to existing mounting holes with the supplied hardware"
Roger
BlackZR1 is offline   Reply With Quote
Old 08-25-2015   #14
Fully Vetted
You're right. My bad. I thought I remembered having to drill a hole. Actually it's a bracket you have to replace with the supplied bracket. Again, the only reason for having to take off the wheel is to gain access to that bracket. Still, it's a piece of cake mod.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
Old 09-06-2015   #15
BlackZR1
BlackZR1's Avatar
Originally Posted by RussMcB View Post
That's a clever idea, Roger.
I've heard of something similar, from Miata racers. They buy hockey pucks on ebay and bolt them to the frame welds for jacking points.
Simple project is complete. Easy target for jack and large surface for jack stands. Avoids contact with fuel lines.
Roger
