Old 08-18-2015   #1
Default Re: ECM Scanner Recommendations
right, while the Tech 1 has more troubleshooting capability, i think for most engine related issues, the stuff i suggested will be fine..
Yeah the Tech 1 acts as a shunt to the ECM.
Old 08-20-2015   #2
BlackZR1
BlackZR1's Avatar
I bought the ALDL scanner from 1320 Electronics that Jeff recommended. Here is a pic of my readings. Anything look out of kilter? Hopefully the picture will enlarge when you click on it.
Thanks,
Roger
BlackZR1 is offline   Reply With Quote
Old 08-18-2015   #3
mike100
The Tech1 datalogs via the snapshot function. a few seconds before and after you press the button. The data stream is a little limited, but it still stores full records.
Old 08-19-2015   #4
Mike,
How many frames w how many params will it record and can you export?
Old 08-19-2015   #5
mike100
Mike,
I think it does about 20-30 records before and after the trigger point. One thing I'm not too sure of is how many records per second- that seems dependent on the baud rate which would be the same for all scanners and is set by the ecm type. The later LT1 cars seem to have a lot more information on the datastream than the prom type ecm's for instance.
There is also a way to output serial data to a vt100 terminal (or terminal emulator) that I'm interested in trying because the little gray screen is only 64 characters and it is hard to scroll back and forth. The Tech1's do have a printer output feature, but it would be more useful to have .csv files. Maybe the terminal emulation data could work like that. Of course there's Moates gizmos...
Old 08-19-2015   #6
Mike,
Moates stuff is just ECM only, which I think for the OP would be better than hunting down a Tech 1 to buy.
I have a Bluetooth and USB interface for the ALDLDroid, then I buy ALDLDroid once and it is on my Tablet, Phone and Android Headunit..
Tablets are getting cheaper, in fact i have a Nexus 7 (2012) I am selling that I know works with ALDLDroid
Old 08-20-2015   #7
BLMs are 115.. Should around 128 problem is this is a snap shot.. Not a log
