Old 08-08-2015   #11
Default Re: Source for Oxygen Sensor Wheatherpack Plug
I get all my OEM type connectors from Terminal Supply. The only problem with the CLOCKED TOWER CONNECTORS is they don't always have the correct mated connectors but are easy to deal with. Unlike White Products,not the hack in Florida,you have to buy a large quantity. At TS you do need a minimum $20 order.on positive about buying something from TS is once you make a purchase you get a catalog. They have pretty much everything at this place,weather pack seals,correct Packard crimping tools,the correct crimping tools for the weather pack seals, the tool to release the terminals from the connectors ETC. When I made the emergency jumper for the fuel pump I couldn't find the right clocked set for the jumper but I really didn't give it much effort.
Old 08-09-2015   #12
Jagdpanzer
Jagdpanzer's Avatar
Thanks for everyone's input.
Brother Yun came over yesterday morning and repaired it in just a couple of minutes with and extra shell he had.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
