#11 |
I thought the secondaries were actually in the injector housings. I am referring to the valves themselves.
#12 |
![]() Join Date: Mar 2007
You can port and leave them in the head.....the 2ndry ports are full sized 35-36MM in the head
#13 |
The secondary throttle plates are in the cylinder head at the IH/Cylinder head interface. As Lee stated, when I port matched to the IH, I only did the primary ports. I did do the head match w the heads on the motor. My garage looked a bit like a a surgical theatre w plastic wrap over the motor and only an opening over the cylinder I was working on. Used pillow foam to block the runners and would vacuum everything before removing that. As a final, I used 6" QTips dipped in Vaseline to clean up any burrs by the valves.
#14 | |
![]() Join Date: Nov 2007
Engine covered w/ plastic shower curtain. Only the port being worked on exposed (see ball gauge used to check clearance into the head(s). ![]() Oiled, blue shop towels (x2) stuffed into the bottom of the ports to catch debris. ![]() |
#15 |
Forum Chairman
![]() ![]() Join Date: Feb 2024
#16 |
Pete and Marc both do porting.
