Old 07-06-2015   #11
Arctic91
Arctic91's Avatar
Default Re: Removing transmission fill/drain plugs
Thanks for all the suggestions and ideas... there is not much of a lip for a set of vice grips to bite into on the outside, but I'm thinking that I'll try heat, with a slightly oversized torx bit pounded in (which should also give the "shock" effect to the threads), followed by an impact hammer and chisel at an angle to see if I can at least get it started. There should be enough of a lip for that.
If that all fails, maybe a bolt head welded onto the plug?
Anyone have success with any extraction products along the lines of this:
http://www.use-enco.com/CGI/INSRIT?P...FdUXHwodcGkMBA
Scott
'95 Callaway SNAT 450 Aerobody Coupe - Black/Black
'92 Callaway SNAT 400 Convertible - Polo Green/Beige
'91 ZR-1 #1231 - Arctic White/Saddle (SOLD)
'90 ZR-1 #2547 - Turquoise Metallic/Black
'89 Callaway Twin Turbo Aerobody Coupe #027 - Black/Black
'85 Corvette 454 Coupe - White/Red
Arctic91 is offline   Reply With Quote
Old 07-06-2015   #12
5ABI VT
This is what mine looked like. A socket later rounded it but the vice grips did the trick.
Old 07-06-2015   #13
Racinfan83
I sprayed mine with PB Blaster and let it soak for an hour. Then inserted the allen wrench, and used a 1 1/4" box end wrench as a cheater. Worked like a champ...
[LEFT][SIGPIC][/SIGPIC][/LEFT]
[CENTER][COLOR=Indigo][SIZE=4][I][B] **Now Sold** 1990 ZR-1 #2093, Black on Black..[/B][/I][/SIZE][/COLOR][/CENTER]
Old 07-06-2015   #14
Mystic ZR-1
Mystic ZR-1's Avatar
WOW!
What did you run over to do that?
Old 07-06-2015   #15
AutoZone sells some 1/2" drive, (17mm) socket allens. I put a piece of water pipe on the breaker bar, as I recall and it came out.
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-06-2015   #16
WVZR-1
Scott
No to the extractors and if you found a "tall nut" that fit the M17 hex then the welding idea works well OR just weld the M17 hex from a cheap socket bought from the AP stores or Sears. An exhaust shop that does exhaust all day long would have it done in likely 20 minutes or less.
You mentioned over-sized Torx and there's no Torx involved. Space constraints make the other ideas less likely. The plug if it's OE is steel and weldable. If you've doubts check with a magnet.
Get yourself a couple of the VW plugs that I've suggested previously and Cliff mentions but make sure they sell you the part number I mention. There's a later plug that uses a VW spec tool for removal and you'd like to avoid that. Let the exhaust shop loosen the drain for you also, return home and complete the project.
