Old 06-29-2015   #1
Default Re: A little wot video of my Z !!
We loved it!
Ami calls them "victims", and would hammer the Turq Monster just like that, given the chance!
Old 06-30-2015   #2
5ABI VT
Heres an old video my friend made with his android phone .. you can hear the sound while decelerating.. no popping at all
https://www.youtube.com/watch?v=gSfP1PJI304
And heres a short clip from the other day of the snap crackle and pop..
https://www.youtube.com/watch?v=M8AnmlUNxNU
Old 06-30-2015   #3
The snap,crackle, pop comes from excess fuel being mixed w fresh air sucked into the exhaust due to the high vacuum created on decel. Ever see any ricer with a "fart can" that isn't completely BLAAAAACCCK from the soot of too rich a mixture?
Old 06-30-2015   #4
5ABI VT
My tips don't blacken much at all but from what I know and can google.. that's the cause as you mentioned. Theres a dramatic difference from the first video though.. none at all.. and just excessive in the re-tune after the top end porting/secondary elimination
Old 06-30-2015   #5
Eliminating secondaries really doesn't have anything to do with it. On decel, the throttle is closed and secondary injectors are shut off. What happens is that with the changes, the fuel map needs to be modified. I have no secondaries, ported heads, more aggressive cams, headers blah blah blah. No gurgling.
Old 06-30-2015   #6
KILLSHOTS
If all you have is "popping" on decel, then it's probably not an issue with Marc forgetting to enable that feature. Mine was BACKFIRING!!!! I mean, pretty much every time I depressed the clutch pedal (even on slow 1-2 upshifts) the car sounded like it was going to explode. Popping on decel is just your low-restriction exhaust...my stock Stingray even does that when I have the valves open.
Old 07-02-2015   #7
Fully Vetted
Fully Vetted's Avatar
You can see my mods in my sig (no cats). I don't have much popping but I def have dark tips.
_________________
1994 AB/Grey #141
430 RWHP/392 RWTQ
BBC - Bling By Carter:
Old 07-02-2015   #8
5ABI VT
Originally Posted by We Gone View Post
I was having some backfire on rapid deceleration and it was having a hard time stabilizing rpms at the same time, and some lag in light throttle response. I have a scanner that I can watch and capture data. What I saw was the right 02 was reacting very slow and not cross counting as fast as the left and the numbers were off compared the the other. I replaced both 02's got them from Jerry's car runs great now.
Let me add I still have secondary's and high flow cats this was on my 91.
Which o2s did you go with ? Wondering if people on this forum prefer a Bosch or denso (I'm a denso fan personally) or ac delco etc?
Originally Posted by WydGlydJim View Post
One of my favorite Zs!.........
little WOT in the white beast..
https://www.youtube.com/watch?v=xCAT4uEiQzM
https://www.youtube.com/watch?v=VQgkV0D1NCo
That's a beast !! Man I love the white Zs
Old 06-30-2015   #9
5ABI VT
I hear you but play the first video I linked when I posted 2 just above.. That was with the same exhaust setup. Absolutely ZERO popping at any speed. The only changes since have been ported top end and secondary system eliminated. That's all. And now there is a lot of snap crackle and pop all the time. The only other thing that was changed was the chip was revised for secondary elimination and porting.
Old 07-01-2015   #10
My Z is a mixed bag. It is fully ported, etc (see signature at bottom) and on hilly terrain (e.g., "the Dragon's Tail") on some decel stretches I'd get popping, etc. But, on others It would stall out until I blipped the throttle and it would "be nice" for a while. Probably needs to have hands "laid" on (the chip) at some point. Runs like a scalded dog, otherwise!
