Old 05-30-2015   #11
Demps
Demps's Avatar
Default Re: Throwout Bearing???
Not "bad" per say. It is solid (unless roller type). The noise is most likely from it slipping/spinning in back of crank.
I'm out of town but can help in a couple of weeks if needed. I use a harbor freight blind bearing puller to remove it. And an undersized-to-bore socket to reseat. May consider new clutch disk, at a minimum, when changing.
Ted
Old 05-30-2015   #12
Originally Posted by cadillac531 View Post
Thanks for the reply. In a previous post I found, Mark Haibeck suggested this pilot bearing gm pn14061685 saying it won't come loose. Do you happen to have a part number for the brass one you suggest?
Thanks.
Here's one from Jerry's Gaskets.
http://www.jerrysgaskets.com/bushing...lot-90-95-8b2/
Apologies. BRONZE not brass. Thanks WV!
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 06-09-2015   #13
cadillac531
cadillac531's Avatar
Ted
It is stock from the factory. Did they come only with the solid one? Also should I be concerned with damage to the crank?
Thanks.
Constantine
Registry Founding Member #0235
1991 Corvette ZR-1 -- Stock, 94 ZR-1 exhaust system, muffler delete.
1956 Chevrolet Belair -- Pro Street, 531ci Cadillac, 8-71 Blower, 8pt roll bar, built TH-400, 9" rear, 1,100 HP -- Street Car.
https://www.youtube.com/watch?v=z8y4cwcvK0s
1968 Mustang "Pegasus" -- Zeeker Chassis, 584ci Dart Block, Brodix Big Brodies, 2-1150 Dominators, FTI 'Glide, 1168 hp, best ET & Trap(holding back) 8.57@159 -- 7.9X -- 1/4 mile car.
1970 Chevelle -- 468ci, TKO600, shaved and smoothed everything.
cadillac531 is offline   Reply With Quote
Old 06-09-2015   #14
Demps
Demps's Avatar
Thanks.
Yes (I think).
No. I haven't heard of or seen damage and as short of a time as you've experienced it I wouldn't think so.
Ted
