Old 05-25-2015   #11
Default Re: Oil leak help...
Originally Posted by bans25 View Post
Oil leak on pass side of the block I think it may be this sensor near oil dipstick? Any idea what this sensor is? Does this typically leak oil or probable it's something else leaking? I have about 40k miles on my 90.
Thanks much!
A bit more information on exactly where the oil is "dripping" from and how much?
Is the oil dripping from the side of the oil pan and between what two oil pan bolts?
One method to use is to pressure wash the under side of the engine including from top right and left side (under hood) just below cam covers (when engine is NOT hot). Do not get water below the Plenum in the Valley. After the pressure wash it is then much easier to see fresh oil leaks.
Old 05-25-2015   #12
bans25
Originally Posted by GSJoe View Post
I wonder if we're talking about the same switch. What you're looking at in these two links is a low oil level sensor located on the pan of your engine. That's not the switch I wrote about in a post above. The switch I'm talking about is located at the bottom of the oil filter housing. It's near the dip stick tube which is what you mentioned in your post. Here's a picture of an oil filter housing removed that shows the low oil pressure switch for the light on the dash. If we're talking about the same item, its GM part number is 25036935 or AC Delco D1846. It's an easy part to buy.
Note that it has only a single wire attached to it.
The sensor/switch I am talking about is not on the oil filter housing, its back right next to where the oil dipstick goes into the block and just behind the motor mount.. the oil filter housing is closer to the front of the car.
This one has me confused so far
bans25 is offline   Reply With Quote
Old 05-25-2015   #13
bans25
Sensor is circled in the picture. I cleaned up the oil when the car was on the lift and let it run for about 20 mins, you can see the fresh oil in the area. I think its coming out from the right side of this sensor? it does not seem to be coming from above but its possible I am mistaken. If I can find one of these sensors I plan on just replacing, cleaning it up again and running to see if this is the leak..
Old 05-25-2015   #14
why not just replace the o-ring?
LGAFF is online now   Reply With Quote
Old 05-26-2015   #15
bans25
I have not pulled the sensor out yet but could try replacing the o-ring, I am still confused on what sensor this is (since its not on the oil filter housing), I am assuming its a oil-level switch?
Old 05-26-2015   #16
It is the crankshaft position sensor.
1990 does not have an oil level sensor.
A26B is online now   Reply With Quote
Old 05-26-2015   #17
bans25
thank you, I just looked up the crank position sensor and it does look much closer than other sensors I have been looking at.
When I pull this, replace the O-ring and re-install, is there any case learn procedure that needs to be run?
I appreciate all the help! Will be nice to clean up this leak.
Old 05-26-2015   #18
Jitse
You can take out the sensor without any problem, it can be sticky but play a bit with your fingers and you can pull it out. I am taking of the - pole from the battery when working on electronics / engine.
If taking off the negative cable, computer needs to learn again after connecting battery.
Jitse is offline   Reply With Quote
