#11 |
![]() ![]() Join Date: Aug 2005
Glad you got the hood open. I could never get Gordon's tool to work.
Just for that reason: (see post #6) http://www.zr1.net/forum/showthread....highlight=hood And there is a way to jumper the fuel pump directly from a wire out the backside of the ECM. You can also switch the 12V feed from primary to secondary pump to see if just one is bad. Last edited by tf95ZR1; 05-07-2015 at 07:35 PM. Reason: Wanted 2 |
#12 |
From Marc Haibeck's website:
http://www.zr1specialist.com/HAT%20W...Tanker%201.pdf "The fuel pump test connector is located near the windshield wiper motor. It’s a single pin connector with a red wire. I made a cable with a spade connector and a clip to connect 12 volt battery power to the test connector. The wire should be 14 gage since the two pumps draw a total of 10 amperes. To run the pumps the clip is attached to the positive terminal on the battery. On ’90 cars with VINs less than about 800 the fuel pump test connector is located in the area of the lower right side of the battery. On the early ‘90’s the connector is hard to reach and may be impossible to find without removing the battery. Starting the engine cold can run the pumps but the secondary fuel pump will shut down when the engine temperature reaches 176 degrees." Last edited by tf95ZR1; 05-07-2015 at 08:00 PM. Reason: Wanted 2 |
#13 | |
![]() Join Date: Feb 2006
#14 |
![]() Join Date: Jan 2015
Great news. My No Start condition was caused by a bad wire/connection at the top of the gas tank. We were able to determine both my pumps are working, but the primary pump was not getting 12v. Specifically, it is one of the male pins in that top plate. It's still giving us grief, but at least now we know exactly where the problem is.
Woohoo! A huge thanks to all of you. After I nail the FP wiring issue, I'll tackle the hood latches (and then start on the rest of the list). |
#15 | |
![]() Nice to solve one of these intermittent and hard to diagnose issues ![]() |
#16 | |
#17 |
Thanks, Dynomite.
Quick summary (in case it helps someone someday):
I've tried to repair the terminals but it's still not quite right. Probably just too old and needs to be replaced. I'll work on it some more tomorrow in daylight, and it shouldn't be too tough to resolve. |
#18 |
![]() Join Date: Dec 2003
I think you guys did some great work. The problem you described can sometimes be very elusive to pinpoint. What you ultimately found is a new-one so far as I can recall & one for the books. Again, great work.
#19 |
Glad to hear you solved the problem, Russ.
I'm picturing myself soldering new terminals next to an open fuel tank.... |
#20 |
![]() ![]() Join Date: Feb 2010
Good job!! Hope to see you in BG!
