#11 |
![]() Join Date: Mar 2004
The rear amp's started giving me some pops on start up and needed replacement. Instead of getting them repaired I bought a set of 100w amps out of a Cadillac. Now there is bass and some good sound in this 94 Bose system.
#12 |
Thanks all, is Dr. Don the only place to get the pig tail adapters for the 1990?
Edit, I emailed Dr. Dons if he had the adapters and got this response: Nissan Amplifiers are not designed for the Corvette Speakers. The Frequency Output for these amplifiers is designed to drive a specific speaker. The Nissan Amplifiers do not deliver as quality of an output either.(Wattage/Freq) So anyone else sell the adapters for the 90? Last edited by SteveCanyon; 05-06-2015 at 06:03 PM. |
#13 |
From which year and model Cadillac did you get your amps? Mine need replacing and I was going to replace the whole system but apparently I won't have to with these.
#14 | |
Clickable links ![]() On Iphone Touchable Links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS |
#15 |
![]() Join Date: Apr 2007
Is it possible to install a standard speaker in place of the amped ones?
lorne # 1748 Stock except for a modified Corsa exhaust. When the flag drops the bull sh1t stops! |
#16 |
![]() Join Date: Feb 2011
You can do that, but you have to also change the head unit and bypass the CDM tuner. There are plug-and-play wire harnessed for aftermarket radios and even some packages with a head unit you can mount too. The Bose speakers are a proprietary 1 ohm impedance. It is all or nothing with these radios. I found that fixing the amps was the easiest solution since I'm not an audiophile and don't need any slick features in a car I don't drive very often.
#17 | ||
There is a set on Ebay right now @ 60. shipped for the pair. I'm looking for a set of 75 watt amps to finish up the front speakers. Quote:
Oh , and Thanks' go's out to LocoBob for the suggestion ! Last edited by FU; 05-07-2015 at 02:46 PM. |
#18 | |
#19 |
Where can I source some pig tails to put new amps in besides Dr. Don's? He is sold out and rather not pay $30 each from the vendors.
#20 | |
![]() Join Date: Jul 2005
Is there a certain year Caddy that you got them from? What should I ask for? Is this a boneyard acquisition or did you buy them new? With my headers, no cats, and old 3" B&B's, I don't suppose I need to be too picky ![]() Last edited by Bob Eyres; 05-19-2015 at 08:18 AM. |
