#11 |
![]() Join Date: Feb 2011
#12 |
![]() Join Date: Feb 2014
I used Amsoil Synchromesh, could not believe that an oil change from the GM stuff could make such a difference. Shifts better cold, no more gear rattle and as well when hot.
#13 |
From ZFDoc Questions and Answeres
(Q.) I just bought, at the local BMW dealership, 3 liters of the Castrol TWS 10W60 oil. I was surprised to see that it is motor oil. Not being a lubrication engineer myself, who did the investigation and determination that this product is compatible with and good for our ZF transmissions? Jim � Grand Sport Registry (A.) Jim, the C4 Corvette ZF S6-40 6-speed transmission uses engine oil for lubrication. I was told by Jeff Henning, Warranty Administrator of ZF Industries North America, that Engineering of ZF Industries in Germany determined that the BMW imported Castrol (RS superseded by TWS) 10W-60 oil was the recommended alternative to the (GM P/N 1052931) factory-fill oil for use in the ZF S6-40 transmission. In effort to verify ZF Industries alternative lubricant recommendation, we ran our own test series on the BMW imported Castrol TWS 10W-60 oil. Independent testing of the transmission oil samples was sub-contracted out to CTC Analytical Services. The test series went as follows: <1> Spectrographic analysis indicated that it is has full synthetic composition. <2> After 2 hours of operation, approximately 100 miles, oil sample analysis tests indicated that the viscosity rating was reduced from 60 down to a 43 level. No need to worry, this is a normal occurrence for this heavier type of oil. I attribute this to microscopic-level lubricant-strand trimming through operational loading where all of the oil contents has been passed through gear pressure-loading regions at least a few times. <3> At 200 miles, the viscosity level stabilized at a 42 level viscosity since the 100 mile oil analysis test results. <4> At 5000 miles, the oil analysis test results indicated a 40 level viscosity. The test-transmission was completely disassembled and checked for wear. There were no signs of carbon film like experienced with the factory-fill oil. The phosphor-bronze lined synchronizers had no glazing and experienced an average mass loss of approximately 4% based on reserve-wear-range mass equivalency between 0.062"(new) and 0.048"(spent) gap wear/mass measurements. <5> At 10,000 miles, the oil analysis test results indicated a 39 level viscosity. <6> At 12,500 miles, the oil analysis test results indicated a 37 level viscosity. <7> At 15,000 miles, the oil analysis test results indicated a 34 level viscosity. The test-transmission was again completely disassembled and checked for wear. There were no signs of carbon film like experienced with the factory-fill 30 oil. The phosphor-bronze lined synchronizers had no glazing and experienced an average mass loss of approximately 17% based on reserve-wear-range mass equivalency between 0.062"(new) and 0.048"(spent) gap wear/mass measurements. <8> At 15,000 miles the oil had enough phosphor-bronze particles suspended in it that deposits began building up inside of the synchronizer sliding sleeves from the normal centrifuge-like rotational occurrence. In Conclusion, until someone invents a copper magnet, we recommend that the ZF S6-40 6-speed transmission oil be changed at 10,000 - 12,000 mile intervals so as to minimize the amount of deposits of the suspended spent synchronizer material from collecting in critical component contact surface areas. In Conclusion, until someone invents a copper magnet, we recommend that the ZF S6-40 6-speed transmission oil be changed at 10,000 - 12,000 mile intervals so as to minimize the amount of deposits of the suspended spent synchronizer material from collecting in critical component contact surface areas. See LT5/ZR-1 Fluids ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-09-2017 at 01:48 AM. |
#14 |
![]() Join Date: Jul 2007
is the new bottled BMW stuff the same just a different bottle?
#15 |
#16 |
Actually some quick research says the new stuff is different..
I think i will go with Amsoil on the next change
#17 | |
![]() Join Date: Feb 2009
Rich
#18 |
#19 |
I found this Snippet of Info in a thread:
"TWS is tested and approved by BMW to meet the specific requirements for the M series engines - it has a different formulation ( which includes additional synthetic esters ) to the Edge sport 10W-60 to meet the specific BMW requirements and the only spec the TWS meets is BMW. The EDGE 10W-60 is the retail alternative for the TWS Motorsport, which is a workshop only product supplied to BMW dealers. So for the M series asking for the 10W-60 grade, I would recommend either the TWS Motorsport from BMW outlets or the EDGE 10W-60 ( which also only carries the BMW approval ) from retail outlets Hope that helps Kind regards Andy Griffin Castrol Technical Support" http://www.m3post.com/forums/showthr...=906342&page=2 I was not going off the other comments, just this.. So what is different? can it or will it cause issues in the ZF? Amsoil MTF 5W-30 is the same/ similar to OEM and Not stupid expense Also search BMW Forums.. bunch of guys chatting about TWS vs the Edge stuff
#20 |
A Comparison of Castrol TWS 10W-60 Motorsport and Castrol TWS 10W-60 Edge
Bill is now using a Custom blend synchromesh lubricant exclusively sold through Rockland Standard Gear (150SM) but recommends either 150SM, or Castrol TWS 10W-60 or the NEWLY LABELED Castrol Edge 10W-60 which is nearly identical (but now there are two Edges). ![]() ![]() ![]()
Left Clickable links ![]() -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 09-24-2016 at 12:01 PM. |
