05-05-2015 | #11 |
Re: Engine code 61 help
i replaced both fuel pumps and checked the diff sensor under the ecm. The diff/map sensor is fine and the pumps are new. Still not opening the secondaries, hesitating and almost stopping at 5k rpm.
05-05-2015 | #12 |
i did not clear the codes but 61 came up again.
05-05-2015 | #13 |
05-05-2015 | #14 |
peek down between the runners on the plenum and see if the actuators are opening the secondaries.....flashlight might help
05-06-2015 | #15 |
Hey lee that article states that secondaries wont open if any ECM codes are stored so i will clear them after work and pray thats it but i doubt it lol. Thanks. I used a paperclip to read the coded. Can they be cleared in a similar fashion?
05-06-2015 | #16 | |
To reset all the codes, simply disconnect the battery for a minute or so before reconnecting the battery. If the code remains, then it is probably legit. Good luck! Paul.
05-06-2015 | #17 |
Hey Paul. The code has disappeared but comes up when I plug the top right 2 pins with a paper clip. Will disconnecting the battery delete the codes from the ecm memory (as the light is not currently on)?
05-07-2015 | #18 |
Disconnected the battery, replaced the MAP sensor as I found one very cheap and code 61 comes up for a second when flooring the gas. I pulled it after I took the car for a ride. Does anyone live close to NJ and have a Tech 1 that would be willing to help me diagnose this? I replaced the injectors (runs super smooth on regular mode but hesitates on full power), coil packs, fuel pumps, and spark plug wires. Code 61 is telling me I have a secondary issue but it could be anything in the whole secondary system. OOh btw I do not have a vacuum leak, and the pump does run and turn off.
05-07-2015 | #19 |
hook an actual vacuum gauge to tube that goes to the under ecm map sensor for the secondaries. You should get a constant 13 inches of vacuum when you floor it if there isn't a massive vacuum leak somewhere else.
you may have to force the secondary vac solenoid to turn on if it won't activate due to restriction in the ecm with the fault...or clear the code and drive it once. |
05-12-2015 | #20 |
I am going to follow marc heibecks procedure and ground that part in back of the ECM. if the secondaries don't open......it has to be the solenoid, in which case i will have to buy jerrys and alter it or buy a new/used one off a member.
