Old 04-23-2015   #11
Default Re: Cornering Bulbs?
I want to do the cornering lights as well as they are the only inside and outside lights I have not already replaced including the FOGs which are also LEDs
I hope Dom knows the part numbers for the side markers and if they are true plug and play. D
Old 04-23-2015   #12
I will try to pull a bulb this week and look at the socket and compare to the main reverse sockets..
Slowly converting the bulbs
Old 04-23-2015   #13
yeah he got me a set of rear bulbs like he has (for next to the license plate).. in that design there is interference.. I ground the interference off the bulbs and they fit
I want to replace the white cornering light now.. then I will do the markers and turn signals up front..
then the fogs..
The cornering lamps are the same as the reverse lights around the plate.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 04-23-2015   #14
WVZR-1
The LED's maybe confuse me a little, I saw someone post a while back regarding 130* and 360* bulbs and I would have thought for applications where you "want to see" a person might want 130* lamps when they installed perpendicular to the lens as in B/U so as to project out the lens rather than rely on the reflective characteristics of the housing which has likely deteriorated through the years. Of course you would need to be sure you bought a lamp with appropriate lumens. Am I not maybe understanding?
I understand the 360* where the objective of the install is "to be seen". A 130* lamp in stop/tail/turn might actually create a nuisance for the "follower".
Old 04-23-2015   #15
What about the markers ?
Old 04-23-2015   #16
And... Moved to technical section
Old 04-23-2015   #17
WVZR-1
Side markers are 24's. All of the exterior lamp specs are in 8B-24 or 25 in most FSM's I believe.
Old 04-23-2015   #18
I know. I stated the sizes earlier. My question was to Dom
Old 04-23-2015   #19
I think the cornering lamps, and backup bulbs are the bayonet types like this
https://www.superbrightleds.com/more...led-tower/163/
Running lights are the wedge type
https://www.superbrightleds.com/more...edge-base/229/
Old 04-23-2015   #20
WVZR-1
I must have missed something here. I never thought to review the entire thread.
